Question about Dual XD-7500 CD Player
Dual XD7500 Faceplate Problem
I own the Dual XD7500 and I just installed it into my 1989 Chevrolet S-10 Blazer. I know the wiring is hooked up correctly but when I attempt to push the "Open" button so that my faceplate will slide down it comes down for around 2-3 seconds and goes right back up before I am able to look at anything behind the faceplate. How do I fix this?
  • 85 Answers
The faceplate has a loose or broken contact on one of the wires on the ribbon wire located in back of where the faceplate mount. the ribbon wire is expensive and you must open the radio and install it. the wire is about 30 bucks plus shipping from the dual company or namsung. you can also find the ribbon wire for sale at ebay.com or parts.com
Posted on Sep 21, 2009
Can i install my new 350 sbc in my 1989 s10 blazer 4x4 without the oilpan bolted up
you will need to have the oil pan on, its pretty tight when you put in a 350 ,also a 3" body lift will make things alot smoother godbless
Apr 16, 2013 | 1989 Chevrolet S-10 Blazer
1989 chevy s10 tahoe blazer the radio wiring is all messed up in the dash how to find the proper collors and fix it
I would take it to a Audio Stereo Installer, they have the Tools to test and get it right and save you so much hassle... $40 is worth saving the headache
Apr 14, 2013 | 1989 Chevrolet S-10 Blazer
My 1989 S-10 pick up digital dash board lights are out. In a recent heavy rain they came on for two days and are out again. What's wrong and how can I fix it?
wow, where to start. check all fuses under dash. try to push all wire connectors under dash together serching for a lose connection. however with them coming on during a hard rain you may have a short. (worst case senario) a wiring harness replacement is within reason. just quite time consuming to install!
Jun 06, 2011 | 1989 Chevrolet S-10 Blazer
I have a 1989 chevy blazer & the key will not come out of the igniation & the igniation will not turn.
Lock is broke there should be a small pin hole at the back of the lock take a piece of wire or a very small screw driver and push in real hard and jiggle the key. and you should be able to pull the lock.
Nov 06, 2010 | 1989 Chevrolet S-10 Blazer
I have a 1987 s-10 blazer and it will not lock in the front axle when i attempt to put it in four wheel drive thus making the four wheel drive not work.
If the locks are manual for the front axle rather than automatic, then try to twist the locking mechanism into hubs locked position.
If this doesn't work, may have to disassemble it to check that it is assembled correctly at the front wheel hubs.
Aug 13, 2010 | 1989 Chevrolet S-10 Blazer
Need a wiring diagram for this radio
Here is a link to the stereo's owner's manual which will tell you how to hook it up:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/070/070XD7500.PDF
May 15, 2010 | Dual XD-7500 CD Player
Wire for tail lights
it should be a BROWN WIRE for tail lights
if you have a trailer hitch check the wiring harness see if its corroded
hope this helps
Nov 12, 2009 | 1989 Chevrolet S-10 Blazer
My dual xd7500 cd player doesnt turn on anymore while hooked up only the power button light turns on nothing else works this is hooked up in my bedroom but the problem should be the same as in car can...
Is the red wire in the back hooked up to a power source? You will need that in order for it to turn on. It is the wire tells the radio to turn on when you turn your key.
Oct 18, 2009 | Dual XD-7500 CD Player
Dual XD-7500 CD Player Logo
704 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
