Question about Directed Dei Valet 561r Remote Start/Keyless Entry
04 Escalade w / Valet Starter, all works but door locks
Bought a 04 Escalade with Valet Remote Starter system. System was installed at an authorized dealer 2 years ago, was told all was working. Remote Starter works fine, doors however will not lock or unlock with remote. The horn sounds and the lights flash and the arming bulb for the Valet System blinks but the doors are still unlocked. Doors lock fine with the inside door lock button or the key.
  • 655 Answers
Hello 7suds,
Well, I'd go back and tell them about the doorlock problem. I know that 2 years is a little late to start complaining, but it's most likely a really easy fix.
The most probably causes are that the power doorlock output was either not programmed, programmed incorrectly, or it's not connected or improperly connected to the vehicle servos. Have the installer check the programming, especially the doorlock pulse duration. It's also possible that the remote is simply not sending the doorlock signal. Could just be a bad button. Have them switch the doorlock function to the right "AUX" button temporarily and see if that works. But in any case, the system needs to be tested to find out exactly what is causing the doorlock failure.
Hope this helps.
Posted on Jul 16, 2009
03 Lincoln Navigator - No Door Locks, Auto Lights - Already used process of elimination - missing something - Help!
Simple fix; bring the vehicle to the dealership and let them reprogram the system!
Feb 21, 2017 | Ford Cars & Trucks
Out of nowhere, the doors will not lock or unlock when armed, the blue led light stays on constantly after the car is turned off and the horn no longer honks when arming or disarming.
The system is in valet. Press the "F" button twice then, press unlock. This will take the system out valet. This will handle the blue light/horn honk. As for the door locks, that may very well be another issue.
Jun 16, 2011 | 5101 LE 1 Way Car Remote Starter System
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
My led light for my alarm stays on and the alarm dont work anymore but the button still locks?unlocks/and starts
Your system is in valet. To take the system out of valet with remote: open any door, press lock, unlock, lock. Now check the LED; it should be off. Close the door and arm the system to check.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and arm the system. The alarm should chirp to confirm that it is armed.
Nov 26, 2010 | Remote Start System
Doors lock and unlock, but system will not arm. also the red LED is on untill the car starts. How do I get my system back up and running?
The LED light is on solid until you start the vehicle. Sounds like the alarm is in valet mode. Try opening any door, press lock, unlock, lock. The LED light will go out if the system was in valet. For future reference, that is the process for "remote valet". If that does not work, turn igniton on then off, within ten (10) seconds, press and release the valet switch. The LED will go out if the system was in valet.
Nov 15, 2010 | 3100L 1way Security System
My remote starter for my viper 5900 2 way trans isnt working...my battery went dead in the remote, than after i replaced it, it's not working properly
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
Oct 03, 2010 | 5900 SST 2-Way Security System / Remote...
How do I program a Viper 473 V Replacement Remote, to my 2004 Hyundai Santa Fe?
Set lock/unlock button
· open drivers door
· turn key to ON position
· press valet switch 1 time
· press valet switch again and hold
· when alarm chirps press lock/unlock on remote
· release valet switch
· turn key off
Oct 05, 2009 | Viper Security and Remote Start System...
My Python 990 system is acting up.Installed several months ago. Now doors wont lock or unlock and alarm goes off every time the door is open even in the unlock pososition. The vehicle is a 2002 Escalade...
Sounds like you have a bad remote, bad battery in the remote, or it needs to be reprogramed to the alarm. If the alarm has been set with the remote, it will need to be disarmed with the remote as well, unlocking the door with the key and getting in, will set off the viper. If you know where you valet switch for the alarm is(small black push button), just turn the key forward till everything on the dash lights up, push the valet switch for about one second and let go. The alarm should shut off in a couple seconds. This will allow you to drive the car until you get you remote checked out.
Aug 15, 2009 | Directed Dei Valet 561r Remote...
2005escalade remote starter
did you install a "gm remote start bypass", like DEI model 556L?
if not it is the passlock that is not allowing the car to start.
Dec 19, 2008 | Directed Dei Valet 561r Remote...
Security will not reset
The disarm switch on the latch inside the door is most likely defective, pull the door panel and test it for proper function.
Oct 01, 2008 | 1992 Cadillac Seville
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
347 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
