SOURCE: multipoint bluetooth wont work with iphone 3g
I actually have both products, and I was able to get my bluetooth to work with 2 phones. All you have to do is first pair your phone with the H721. Then in the phones functions, turn off the bluetooth so it is no longer in discovery or connected...but do not turn off the bluetooth itself, just in the phones settings. Then go to the bluetooth settings in the iphone. you should see the H721 in discovery but not connected. Before connecting it you must put the H721 into discovery mode as well. Hold all three buttons down for 19 sec. it will go solid blue. then push connect on your iphone. onces connected, go to the original phone and turn the setting back on for bluetooth connection. both are now connected. Only one may apear to be connected, but both are. test it with another phone. call each number and you will see that you can now answer both calls with one device. If the iphone is connected and phone 1 rings...the H721 disconnects temporarily from the iphone and connects to the other device to answer it. Hope this helps. Cause thats how I got mine to work.
SOURCE: bluetooth pairing bmw iphone problem
i dont beleive the i phone is supported. http://www.bmwusa.com/Standard/Content/Owner/BluetoothYourBMW/CurrentlyAvailableCompatiblePhones.aspx
chk. out this link for compatable phones.
SOURCE: i am tryingto pair my iphone with thebluetooth in
The phone needs to discover the car, not the other way 'round.
Make the car BT system discoverable, then on the iPhone go to Settings->General->Bluetooth.
Turn bluetooth on and it will search for devices. It should then find your car, and you can proceed with pairing.
SOURCE: I HAVE HAD MY BT 02A2 PAIRED WITH A NOKIA PHONE, A...
HOLD down the mode, power on and "+" button simultaneously for 3 seconds. This puts the device in pairing mode. Your phone should find it and ask for a pass code. The code is 0000
