Question about Whirlpool Inglis IP4400 Washer
Water will not pump out, no hum or noise what so ever
  • 61 Answers
TRY THE LIT SWITCH PUCH A PENCEL WER THE WASHER LID FRAIM THER WILL BE A OPENING 1INCH LONG THE IS WERE THE SWITCH GO
Posted on Jul 16, 2009
This happened to me - it ended up being a wire that had gotten caught in a spring at the base of the washer. The spring had rubbed through the wire and grounded it, causing it to melt apart.
Fixed by soldering the wire back together and tying it to the base to ensure it didn't get caught in the spring again. I also had to take apart the timing mechanism and pull apart two contacts that had fused together.
Posted on Oct 08, 2009
I have an in ground fibreglass saltwater pool and the water will filter will not pump.
a humming noise is a frequency noise meaning the motor is not running
check / replace the start/run capacitor for the pump motor
call an electrician for a proper diagnosis
Dec 28, 2016 | Pool & Spa
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
What are the side effects over years of use
Ball Bearing needs to change.there is inside the pump a mechanic seal that with the time, leaks water and rust the ball bearing balls and making rusted the shaft .
The pump at this time gets Humming when works.
Pump humming or making noise is not a good working pump.
must be quiet without noise
Aug 19, 2014 | Pool & Spa
Humming sound coming from engine told it was the alternator
This noise could be the alternator, water pump, power steering pump, idler pulley or tensioner pulley. Sometimes an automotive stethescope is used to isolate noises around the engine.
Dec 20, 2012 | 2002 Chevrolet TrailBlazer
Washer did not spin out message E20 appeared on panel. Attempts to start just humming noise.
is the humming comming from the motror trying to run or is it just a humming sound if the machine has washed correctly upto that point then check water pump for faults and or blockage machine will not advance if water trapped in machine the humming sound could be the water pump either free spinning indicating a blockage or humming as it is trying to run indicating a faulty pump
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Frigidaire ATF6000ES Front Load Washer
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
Whirlpool duet washer will not spin. pump drains well. low humming noise.
"low humming noise??" soundslike the pump trying to pump, did you try removing the lower acess panel and physically cleanout the drain pump filter?? sondsas if its still trying to empty water
Mar 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
Nov 08, 2008 | 1995 Honda Civic
Does anyone have this problem
humming noise could be either:
valve energised but no water present
pump energised but impellor jammed by a foreign object
worthwhile checking pump rotates freely and that water is present.
most likely to ber the pump
Aug 31, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Whirlpool Inglis IP4400 Washer Logo
223 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
