Question about Dishwashers
Dishes are not getting clean
The soap is still in the door at the end if a cycle also dishes are not getting clean
  • 6,784 Answers
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Posted on Jul 16, 2009
My FRigidaire GLD2250RDC6 dispenser cup doesnt open after any full cycle. Open the cup manually & the soap cube is still there.
remove door face so you can see the back side of soap door. close soap door and turn timer by hand. watch and see if a part on the trip mechenism is broke.. then replace that part
May 26, 2012 | Frigidaire Dishwashers
The items in the dishwasher are feeling "gritty" and are not clean at the end of the wash cycle
Remove the filter from the lower front section of the wash tub and clean it out.
Then start a wash cycle with no dishes and no soap.
Once the water fills and starts washing,open the door and pour 1 quart of white vinegar in the wash tub.
Close the door to resume the wash cycle.
Let the machine run a complete cycle to the end to help clean out the water ports.
Jan 06, 2011 | Bosch Dishwashers
The soap dish opened, but the dishes were not cleaned. The soap remains on the door even after two or three wah cycles. Checked all of the buttons.
Since you mention that your dishwasher has a dispenser has a flap that opens but detergent does not come out, the problem could be the wash water is not getting to it.
Can you confirm if during wash cycle the water is circulating especially through the top wash arm.
Keep a small container on the top rack and see if there is water collected in it at the end of cycle. Alternatively run the dishwasher with door open (you will have to find a way to enable the door switch inside the latch).
Please post a comment to confirm what you observe.
Sep 07, 2010 | Maytag Dishwashers
Soap tablet not being used,not washing dishes
I will assume a few things as you do not indicate which unit you have.
You have a soap dish with a door that should open at the correct point in the cycle. That is probably not happening. You can tell for sure if the soap dish door is still closed at the end of the cycle.
If the door is still shut then something could be jamming it or it is faulty.
Take a look at the dish door and look for soap residue and dirt etc collected around the hinges and the clip holding the door shut. Clean it out.
Open and close the door by hand a few times to ensure it operates freely.
No Go ?
The timer tells the door when to open and close. If the door is faulty or the timer is not sending the signal then the soap will not dispense.
To test the soap disperser you would open the door and move the timer to the position where the soap should be dispensed. Then put a test light across the terminals on the dispenser to see if it is getting a signal. If there is power then the disperser is faulty. It now power the timer is faulty. You would replace the part accordingly.
It is hard to explain in detail how to do the test as I don't know the exact unit.
Short term solution until you get it properly fixed is to use the puck or dissolving package type cleaner. Just put it in the bottom of the machine at the start or open the door mid cycle (unit stops when you open the door) and toss it in. It will work for now.
Hope this helps you with some direction. Please rate this answer if it helps you get started.
Mar 19, 2010 | Whirlpool 24 in. ADG7540 Built-in...
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Soap dipenser
Try this... Wipe out the soap dish with white vinegar and a soft cloth.. make sure you get everything off the edges of the door and look for any nicks, blemishes or deformation of the dispenser door to make sure it is not mechanically binding up when it is cycled open. If Ok.. then.. clean your drain filter.. then.. start a wash cycle using the hottest setting ( without any dishes) .. and after about 10 minutes or so.. stop the process and open the door and add in 2 cups of white vinegar.. Let it complete the wash cycle.. When complete..try running a dishless cycle on any setting with detergent ( use about 1/3 less than you usually use) and see if that dispense adequately. If that works, then the next time you load the washer. make sure you don't have anything up against or limiting the door from opening. Hope this helps..
Sep 23, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
Cleaning agent not being released as compartment door not opening
For verifining the exect reson for your problem, you can start with a very simple test- Place the dish soap on the bottom of the dishwasher and run it for a full cycle. In case dishes will not become claen, your problem is with the water temp. If dishes will become clean properly, the problem is with the detergent door that doesn't opened at time (operated by a wax motor that get its power from the timer).Maybe that by cleaning the detergent cup you will solve the problem. In case it will not -To gain access to the wax motor you should open door assembly-Find the wax motor (close to the detergent dispenser cup)and test with a multi-meter if it get power(following cycle's sequence).If it get power, you should replace the wax motor. If it doesn't get power the problem is with the timer. Good luck !!
Jun 11, 2006 | Jenn-Air JDB4000A Built-in Dishwasher
Dishwashers Logo
57 people viewed this question
Top Dishwashers Experts
Owen Barnes
