Question about GE Monogram® ZISS420DMSS Side by Side Refrigerator
Refrigerator side freezes sometimes
I have a GE monogram ZISW42DY refrigerator that has the Refrig side freezing sometimes. I replaced the AP2061715 (thermostat damper door) about a year ago too. Are these Thermostat devices troublesome? Also, I see that the sensing coil is wound up next the door - is it suppose to be right next the sensor? I also have a thermometer in the frig section too. I reads about 45 degrees F.
Any ideas in how to fix the frig side freezing?
Krazytech
  • 725 Answers
SOURCE: Refrig section frosting up
do you have frost or Ice .. if you can remove the back cover check the evapator if you have a ball of ice You have a leak ,,, if less them 12yrs old call for service Sub-zero will fix it under warranty
Posted on Jul 08, 2008
  • 69 Answers
SOURCE: GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Posted on Dec 21, 2008
tborn6
  • 700 Answers
SOURCE: GE GSS25PGMCC refrigerator freezing food
hello I think that this is what you are looking for . Hope it helps you out with your problem.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60218.pdf
Thank You for using FixYa
Posted on Dec 25, 2008
appldoctom
  • 311 Answers
SOURCE: kitchenaid built-in refrig 15 yrs old cold freezer, warm fridge
it.s the frezer that makes the refer cold.the evap fan in the frezer moves that chilled air to the refer.if that fan is slow or any blockage inthe air ways it slows that process.Also the frezer should be close to 0 degrees if theres a defrost prob that would make fresh food warmer
Posted on Dec 31, 2008
  • 1169 Answers
SOURCE: GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Posted on Apr 20, 2009
Side by side ge refrig freezing food in refrigerator side temp control working since when turned to zero clicks off what could this be
Probably the temp control is defective and is defaulting to maximum. I would suggest replacing it to be sure.
Feb 01, 2015 | GE Refrigerators
My GE monogram refrigerator keeps freezing up. My repair man has replaced the thermistor and the control board, and neither fixed the problem. He told me to contact GE, but I can't seem to find a number to...
This might seem silly but sometimes having the Controls turned to max will cause a refrigerator or freezer to freeze up.
Another problem could be if there's a water input system that runs through the inside of the unit for ice-makers or water dispenser internally. It could be a broken/worn tubing that needs to be replaced. If there's any water running on the outside or condensation on the tube it would explain the extra water or water vapor that's causing the refrigerator to freeze up.
Does there seem to be a source of the ice, or any place that's specifically worse than others.
Aug 31, 2013 | GE Monogram ZICS360NRRH C... Bottom...
My GE Monogram side by side we can't control the refrig side temp. It just freezes no matter what. We have wasted so much food.
its the damper vent door thats located in the upper left area of the refrigerator compartment and this door breaks and then cant shut to close off the cold air from the freezer entering the refrige,general electric has had a bad problem with these damper vent doors,now they have a new and improved or so they say damper vent door,its about $100.00+
May 29, 2011 | GE Monogram Side by Side Refrigerator
My refrigerator won't stay cold. The freezer is working but not the refrig side
I have the GE Monogram ZISB480 side by side. Once again I have your same problem of the freezer freezing (good), but the refrig does not go below 45-50. All the official repair guy did was do a quick 1 hour defrost. I did that also just two weeks ago and it was fine. Now it is not cold enough again. I just looked in the freezer using a mirror I was able to push a 2"x2" trap door open towards the fridge. It must be automated and malfunctioning. Why the heck the repair guy didn't work on that? This week I'll call for another repair job ($85 for him to just come to my door) and ask him to fix the trap door. -Bob
Nov 14, 2010 | GE Monogram Side by Side Refrigerator
Food is freezing on refrig side. although i set at 46 degrees(fresh food) will drop to 26 degrees and freeze food
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram Refrig. water supply to icemaker freezes
You will need to adjust the temperature of this unit. the line will freeze if the temp is to low.
May 24, 2009 | GE Refrigerators
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Our GE monogram refrig compartment is constantly below freezing.
2 possibilties most likely is a bad temp sensor it thinks its warmer in the refrig than it actually is. the next possibilty is a motherboard has gone bad in the unit.
Jan 21, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Monogram® ZISS420DMSS Side by Side Refrigerator Logo
74 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
