Question about Sony KV-32S26 32" TV
Sony kv30hs420 turns on and off again after 3 seconds
Hello. my sony tv turns on with sound but no picture and after 3 seconds turns off by itself. i also noticed that the red standby light blinks 7 times in series. i cannot afford to buy a new tv at this time so do you think it's worth it to be repaired? i have no idea yet how much the service will cost.
hope you can help. thank you.
  • 73 Answers
Re: sony kv30hs420 turns on and off again after 3...
Replace ic8001 and ic8002.generic part#mcz3001d
Posted on Jul 14, 2009
Check this tread, I had a similar issue you might want to try and tweak the focus and green pots. You will have to remove the rear cover to see these adjustment pots
Posted on Feb 05, 2008
0 characters
3 Points
Will only turn on for about 3 second with no picture and then turns off. Standby light blinks 6 times
For the KV30HS420, 6 blinks, pause, 6 blinks, etc. means "LOW +B OCP/OVP (overcurrent/overvoltage)" and the probable cause locations listed are as follows:
1. +5 line is overloaded (A, B, M boards)
2. +5 line is shorted (A, B, M boards)
3. IC504 is faulty (A board)
hope this helps John
Jan 11, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony kv 27V15: No picture but sound
Hi! the trouble indicates that your television's picture is the culprit, have your unit check by a qualified technician for verification.
Sep 12, 2009 | Sony KV-27V15 27" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Try unplugging the TV for about 10 minutes and then tunung it on again. Try a factory
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
I'm assuming step 2 means hold down the power button.
Nov 27, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
My mitsubishi 1080 WS-55807 has lost the picture
Unplug the set, remove all other audio/video components, go open front door, and roll it out to the curb.
Nov 24, 2008 | Mitsubishi WS-55807 TV
Sony KV30hs420 0 Stanby Light Timer Blinks 3 times and powers TV off
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Jan 25, 2008 | Toshiba CN36X81 TV
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
Sony KV-32S26 32" TV Logo
209 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
