Question about HP iPAQ RZ1710 Pocket PC
Does not hold a charge. I have tried charging it for 2 days and when I unplug it and check the battery it says zero charge and shuts off!
I had that problem in my pda, I didn't see the amber light. I desconected the batery and conected it again and that solved the problem. You can try.
Good luck.
Posted on Aug 10, 2009
If you see the amber light on the charging cradle then your battery no longer holds a charge. if you don't see the amber light then your pda is not charging when in the cradle. most likely it's a battery problem. good luck.
Posted on Jul 20, 2009
Invacare battery charger 24 volts no output if not connected to battery?
If the battery has stood for two years with out a charge it will no longer be able to hold a charge renew it . most modern chargers need to detect battery voltage before they will charge .
Sep 17, 2014 | Health & Beauty
Battery keeps going flat on gilera runner 125vx 4stroke
Three possible issues: Bad battery won't hold a charge or rapidly loses a charge. Bad charging system/ alternator. Current draw on the battery when turned off. Use a multimeter to check voltage on battery terminals when it is running. You should see at least 13 volts. Fully charge the battery for about 6 hours, unplug it from the charging system, and then check the battery voltage. It should be at least 12.0 volts, actually a bit higher. If your ammeter can handle it, you could test for current when it is turned off. You want the reading to be 0 or very close to zero,
Oct 17, 2013 | Motorcycles
Laptop will not power up
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. Unplug your laptop while it is running. If it still works, the battery has been charging. If it shuts off, or doesn't hold a charge very long, you have a bad battery. Unplug your laptop while it is off, then try to turn it on. If the battery is bad, your laptop probably won't turn on at all. Turn off your laptop's screen-saver when testing its battery. The screen-saver will conserve the battery and not give a clear time frame for how long your battery can really last. Click the battery icon on your laptop when it is unplugged. It can tell you how much battery life you have available. This icon is usually located in the bottom right corner of your screen and will provide the percentage of battery power you have left. Keep track of the time it takes to go from 100% charged to 1% charged. If this takes less than an hour, your battery is probably beginning to fail. You can also try this every week or two to see if your battery holds a charge for shorter periods. Factor in the amount of time you have used your laptop. Most laptop batteries last 2 to 3 years or about 500 charges. Wait a few days before determining whether a new laptop battery is faulty. New batteries sometimes take a few charges to build up to their maximum run time.
Feb 10, 2013 | Toshiba Satellite Computers & Internet
My philips gogear 4g is pluged in and works but when i unplug it it says low battery and shuts off immediatly it has been left on for 4 hours now trying to fully charge it will not charge is the battery...
If the media player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 26, 2011 | Philips GoGear ViBE Digital Media Player
I donot know what is wz my battery but it is show 100% but in real it is like 15% plus it is only stay like 15min while it is unplugged
This is a sign that you need a new battery. If you can not get a new battery try calibrating the old one. Here's how:
1. Charge the batter to full. (I know you stated it is like 15% but charge it till it shows full.
2. Unplug the AC adapter and let the battery drain. (If your notebook shut down b/c of low battery, keep powering it on until it will not come on anymore.)
3. Once drained, charge it again to full power and repeat the process at number 2.
4. Finally, charge the battery again. This time it should be recalibrated to hold a full charge close to the factory setting.
Good Luck
C2Solutions
Feb 19, 2011 | HP Compaq nx7300 Notebook
When my acer aspire 5734z laptop is plugged in the charger indicator flashes and the battery indicator shows blue.it stays at 0% and says plugged in,not charging.if i unplug the charger it shuts down. need...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 11, 2011 | Computers & Internet
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
BATTERY WILL NOT HOLD CHARGE
check your alternator, for proper charge
Jul 16, 2009 | 1995 Chevrolet Lumina
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Mp3 player
Well, charging the battery alot may cause it to malfunction. So you have to charge your battery only when in is near zero (empty), and for no more than 8 hours depending on what device you use. Now your battery is dead, so you got to replace it. Goodluck
Feb 11, 2007 | Neuros (4010100) (128 MB) MP3 Player
HP iPAQ RZ1710 Pocket PC Logo
223 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
