Question about Royal 15MX Shredder
Royal HT88 8 sheet crosscut shredder
Royal HT 88 only works in reverse after clearing jammed paper
fellowesrep
  • 102 Answers
SOURCE: Royal HT 700X Shredder
You should be able to get help at 888-261-4555
Posted on Mar 02, 2008
  • 45 Answers
SOURCE: Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
Posted on Apr 16, 2009
FixinFax
  • 3085 Answers
SOURCE: Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Posted on Aug 02, 2009
I have the same problem... The shredder will work in reverse only. Nothing at all happens while in the automatic position. I checked the back side of the circuit board for anything out of the ordinary. There was a hot spot on the back just opposite a zener diode and a resistor. Considering how these arn't expensive shredders, I just bought a new one.
Posted on Jan 27, 2010
rezazadeh
  • 328 Answers
SOURCE: A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
Posted on May 23, 2010
My royal sp12mx will work in reverse but nothing happens when i insert paper to shred. light is on
there is a very small lever between two cutters around the middle that activates a microswitch to turn it on when you offer paper to be cut
the problem will be in that area ( switch or lever broken) as it's purpose is to switch on the cutters
reverse is straight drive from the control switch
Aug 27, 2016 | Royal SP12MX 12 Sheets PP Security Plus...
Dynex shredder only works in reverse
If your shredder is jamed with paper, the centre of your machine has a switch which is plastic. If there is paper under this switch it will prevent it from being pushed downward, it will not shred paper, it will only work in reverse. Unplug your machine and clear the paper jam so the little plastic switch will be able to go down and it should work. Hope this works for you.
Sep 23, 2014 | Dynex - 10-Sheet Crosscut Paper Shredder
How to fix jammed paper
Put it in reverse and then but in less paper at one time.
Jul 24, 2014 | Royal 89119W 120X 12-SHEET CROSSCUT...
Paper jam both forward and reverse are not shredding it is a clump of papers and I can't get it lose
Sound like a serious jam up. Try a sharp small screw driver to flick out jammed paper and try rotating by hand. Caution ensure it is unplugged and use gloves to protect from sharp edges. With the clump of paper try a LITTLE water to soften the clump. Good luck.
Aug 25, 2013 | Royal 1840mx Crosscut Shredder
I have paper jam in royal px1201 12 sheet crosscut shredder.
turn unit off and slowly pull straight up on the jammed paper. Next time dont try to get rid of the evidence all at once
Feb 26, 2013 | Office Equipment & Supplies
I have a Royal CX 66 Crosscut shredder and attempted to shred 10 pages. The unit shredded 1/2 of the papers and the other 1/2 are stuck in the shredder; the reverse mode will not release the papers. Is...
The Royal cx-6 shredder is a small consumer shredder rated for "up to 6 sheets at a time" so yes it will jam with anything more that 6.
If running it in reverse won't work you will have to try to open it up and see if you can manually turn things to get the paper back out...there is no other way if it wont run in reverse...hopefully when you have the paper removed the machine will still function.
Oct 27, 2010 | Royal CX6 CrossCut Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
May 22, 2010 | Royal CIA 12X Shredder
Aug 02, 2009 | Royal VF1012mx Shredder
Royal 15MX Shredder Logo
387 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
