Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Water is not getting into the unit at all - maytag dishwasher model mdb7160aww
  • 6,784 Answers
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Posted on Jul 16, 2009
Does the dishwasher dwu9200aax dishwasher have a capacitor? I can't find it on the schematic. My dishwasher fills w water and only hums during the wash cycle. No spray or physical movement. There are no...
So this is a Maytag their is a relay on some, usually by the right front corner or in the front edge near the electrical box, is the motor that's humming ? Was the unit noisy before this problem occurred ? Is it a digital control model or timer, maytags reverse direction for wash then drain. Need this info ?
Oct 30, 2013 | Dishwashers
Maytag mdb7160aww dishwasher not cleaning dishes lower arm not turning fills and drains okay
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jul 13, 2011 | Maytag MDB6000 Dishwasher
I have a Maytag dishwasher model #MDB7160AWW. I am finding a cloudy residue on my glasses and cups on the top rack. Our water is hard. When the washing cycle is completed, there is still soap residue...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Apr 14, 2011 | Dishwashers
Maytag dishwasher #WU484 will not fill
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at http://appliancehelponline.com/dishfloatwaterinletvideo.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Jun 18, 2010 | Maytag Dishwashers
I have an maytag dishwasher and i can not get the water to come into the dishwasher i have everything hooked right it has power when i turn it on it just want let water go into it
you must prime all new installs on dishwashers. this means you must put about a gallon of water in the unit on the first wash.pour a gallon of water inside the dishwasher on the bottom ,close the door and run as normal.water will start to come into unit.good luck with your project.
Aug 04, 2009 | Maytag Dishwashers
Maytag diswasher won't spray water
water level/float switch is stuck. (dishwasher is getting a indication the unit has enough water in it to operate)...repair/replace float switch, located in front right corner under bottom rack.
clarkco
Feb 28, 2009 | Maytag 24 in. MDB9750AW Dishwasher
No water comes in to wash dishes.
sorry to sound obvious, but you will have pull the dishwasher out to get to it, just follow the hose into the inlet valve unit, they are located under the unit at the back.
Jan 27, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag MDB7160AWW fills water for a minute then stops
hi there,
please provide the model # and any error messages on the display please.
thanks,
c
Jul 24, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag Dishwasher
Newer Maytags should fill close or up to the heater not over. Sounds like your alright for now but I would get that water line fixed.
May 15, 2008 | Maytag 24 in. MDB8951AWS Stainless Steel...
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
156 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
