Question about Apple iBook G3 Mac Notebook
IBook never completes loading, stuck at ble progress bar
I tried loading from the CD by holding down the "C" key when I hear the chime but I must have some major problems. You can hear the attempt to access the CD and the screen displays what appears to be he universal symbol to power on (circle with a vertical line extending out of the circle). This symbol is overwritten with text in 4 languages telling me hold down the power button for several seconds to restart. This symbol is also overwritten by a command screen. The last 3 lines are:
Kernel version:
Darwin Kernel Version 8.4.1: Tue Jan 3 18:27:02 PST 2006:root:xnu-792.7.90.obj~1/RELEASE_PPC
panic: We are handing here...
I must have either major hardware problems since it won't let met boot from CD or major software problems.
FYI - I also ran a system check (Fsck) which displayed everything was OK. I am open to suggestions.
  • 126 Answers
I am running off memory, but I belive you can also hold either Option or Command key at chime startup and it will give you a visual option with booting to hard drive or disk drive.
Try that and see if it will show the option to boot from CD.
I would suggest probably reinstalling OS X
Posted on Jul 16, 2009
Stuck on safe mode screen says panic: we are hanging here...
Try switching off the machine and unplugging. Leave for 5 minutes, then plug back in and switch on, once you hear the first chime from the computer, hold down the alt+cmd+P+R keys (PRAM). Until you hear the second chimes, then let go the keys. If this doesn't work I suggest the same procedure with the switch off etc...but this time when switching back on immediately hold down the 'C' key (don't wait for chime) and start in safe mode. Once you are there reinstall the Operating System from the disk. Alternatively, if you can get to the disk utilities runs a check on the hard drive and hit "repair'.
Try this...hope it helps
Regards
Sep 30, 2014 | Apple iBook G4 Mac Notebook
When i turn my Macbook pro on I get folder with a ?
not seeing start up disc.
Try restting pram or nvram is also called.
hold down apple key, option key and the letters p and r and then push power button. These four keys must be pressed and held down continuously before the first chime and until you hear the third chime.
if that does not work, try going to google and doing a search for apple key commands in apple support. I think holding down the option key before pushing power button on a machine that is powered off will take you to the drive select menu. where you can choose the drive you want to start form.
YOu can also try installing system disk and hold down c key. Go into disk utilities and run all four choices.
May 12, 2014 | Apple iBook G4 Mac Notebook
Reset computer
when computer is plugged in and powered off, hold down apple and option keys on left side of space bar and p and r keys. Keep them all pressed and hold them and push the power button, keep them down and listen for the boot chime to happen three times.
THis is resetting the pram or nvram.
Also try disk selct by holding down the option key or maybe try safe mode by holding down the s key.
Apr 08, 2014 | Apple MacBook Air
My ibook stays on the white screen but the apple and the spinning thing doesnt show up but i hear the chimes and i am trying to download my new os x software please help me get it to work
You may have a bad hard drive. The "chime" means that the iBook was able to power on, and the white screen means that it foung the efi or firmware, but the fact that it will not go to the apple or the spinning gear means that it cannot detect an operating system on a hard disk.
Do you have the OSX CD? Put the CD in your ibook, power it on, and hold down the "C" key. This will allow you to boot to the CD. if the hard drive is still good, then it will allow you to install, if not then it will tell you there are no hard disks available. Hope this helps.
Mar 14, 2011 | Apple iBook G4 Mac Notebook
My Ibook A1005 (2002) model,just wont boot up,I press the power on button,the Apple sign comes up,and it just continues to load with no results!!!!It was working just fine,can anyone assist me
Sorry to hear about the trouble you're having - there are several things that could be causing this.
Firstly, if you have the original disks that came with the computer, try turning it on, loading the restore disk in, and then restarting, holding down the C key. This will boot from the CD, and you'll hopefully be given a set of options. If that works but you don't know what to do next, please let me know.
If that doesn't work, then I'll need some more info. Boot up the iBook, and hold down the Command and V keys - this will boot in verbose mode, which gives you more information about what's happening. See if the computer gets stuck at one particular instruction - then let me know what it is, and I may be able to suggest how to sort out the problem.
Hope that helped, good luck!
Dec 13, 2010 | Apple Computers & Internet
When I start up my G4 I doesn't get past the white logo screen with the circular icon spinning. Have removed battery and depressed start up button until a loud beep occurs but still nothing
I had a problem with my hard discs. That's where I got, but my screen froze after a few minutes. try pressing apple + s after the chime. See if you can search around there. Also, try holding the shift key when you hear the chime, or when booting if you don't normally hear the chime, and hold it 'till you see the apple logo.
Jun 07, 2009 | Apple iBook G4 Mac Notebook
Just repaired g3 ibook. Hard drive needs formatting, as it has xp loaded on it. Ibook starts up, boot tone, proceeds to load, then screen has a file in the center of screen with the osx finder square face...
With the OS X Installer CD in the drive, try booting your mac and holding down the option key immediately after you hear the start up chime. This will (hopefully) load a firmware boot loader that will show available start up discs. Hopefully the OSX installer will show up as CD Icon. Select the Icon with your mouse or keyboard and press enter to start up with the Installer CD. From the installer you should be able to erase and format the drive as Mac OS Extended before installing OS X.
If the computer still won't boot from the CD double check that it is a retail OS X installer CD. If your CD has "software restore" or "ibook restore" or any other varient of restore written on the label; or if it names a particular model such as "ibook install" or "imac install" it is not a retail copy and may not be a bootable disc. A retail copy will only name the version of the operating system followed by the word install written on it's label and usually have a brief instruction on booting from the CD by holding the C key at startup.
Hope this helps, let me know what happens.
Apr 03, 2009 | Apple iBook G3 Mac Notebook
My iBook G4 continues to run slowly and/or freeze
Try resetting the PRAM by turning on the iBook then holding option + command + P + R and wait till u hear another chime. If it still freezes, it may indicate an application may be causing it to lock up hold shift after you hear the chime to boot OS X into safe boot.
Mar 18, 2009 | Apple iBook G4 Mac Notebook
I have a clamshell ibook wich freezes on start up
Zap the PRAM. Hold down "P" "R" "OPTION" "MAC LOGO" keys and power up. Hold down keys until you hear the the starting chimes 6 times. Also try booting from the CD. Insert in CD drive and restart holding down the "C" key.
Dec 12, 2008 | Computers & Internet
We have an older ibook **** shell computer which freezes in start up.we do not own a recovery cd or a operating system cd. any clue what to do or purchase to fix it?
I would first try to reboot the PRAM.
The Perameter ram stores data for your start up and something there might be the culperate.
TO do this hold down the shift and "P" and "R" keys as you hard boot it by holding down the power button for 10 seconds. Release the power button and hold those above keys (shift, P, R ) down until you hear four chimes. Then let them go. It should boot fine then. If it still freezes, write me back.
Dec 12, 2008 | Apple iBook G3 Clamshell (M2453B) Mac...
Apple iBook G3 Mac Notebook Logo
184 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
