Question about Ryobi Garden
Ryobi 775r won't start. I replaced the spark plug but still no go. I have never replaced the fuel line didn't know that was necessary
  • 112 Answers
Make sure you have fresh gas miture first, then put spark plug on housing as you pull it over (with the switch on) watch for spark if its there then its a gas problem. old stinky gas is usually what happens when it sits for months. carb may need to be rebuilt if it still won't start. also check exhaust screen to make sure its not plugged.
Posted on Jul 16, 2009
2 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: fuel line routing on ryobi 775r
One line ( the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Posted on Sep 01, 2009
Testimonial: "MAN I LOVE THIS WEBSITE,,IM VERY MECHANICLY INCLINED,BUT SOMETIMES GET STUCK,I FOUND THIS WEBSITE,ASKED,AND""POOF""-CANBRUCE75 HELPED ME,,THANK YOU."
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacing fuel line on trimmer model 775r - have have removed all the fuel lines and the bubble, but have forgotten the exact pattern to replacing the three fuel lines
Hi: I'm a new user to this forum. I recently had to repalse the 3 fuel lines on my ryobi model #775r. After researching the problem, I diagramed the flow of fuel in order to repace the fuel lines. If you require a copy of this diagram, send me an email . Regards, Tony
Oct 07, 2010 | Ryobi Garden
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
I can not start my ryobi 775r trimmer. There is fresh gas and the fuel/oil mixture is correct. I've gone thru all the starting procedures in the owner's manual including for flooded engine. I installed a...
Remove your spark plug, take a rag and dry it up shoot a little WD-40 into it reinstall. Do not prime the unit or turn the choke on just pull it should start for you, make sure you are are not leaving the choke on, that is a common mistake.
Oct 10, 2009 | Ryobi Three Trimmer Combo
Fuel line routing on ryobi 775r
Sep 01, 2009 | Ryobi 15" Electric Factory Reconditioned...
MY RYOBI 31CC 775R WEEDEATER WON'T START I REPLACED THE SPARK PLUG AND STILL NOTHING I DON'T THINK ITS GETTING GAS HOW DO I FIX OR REPLACE GAS LINES.
spary a little startingfluid in carb to see if it start if it start rebuild carb.to change fuel line
only if there dryrotted if it go thourght the gastank in little hold cut new line on a angle and thread through hold.hope helps you.let me know ok
Jul 24, 2009 | Garden
Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Jul 17, 2009 | Garden
RUNS AND STALL WHEN YOU GIVE IT GAS
you are right on. try richer mixture.
May 22, 2009 | Ryobi Garden
Ryobi 18" petrol chainsaw won't start
my guess is that you have a crack or a hole in one of your fuel lines. this is very common in chainsaws and weed eaters because they are used very little and sit for a long time. try checking this and repair if necessary. let me know if this works.
Mar 08, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
338 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
