Question about Plumbing
How do i fix low flow on hot water on a kitchen faucet?
Hot water butterfly valve is open. All other hot water taps in the house are full pressure. Hot water heater replaced in the last month.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Have you found a solution yet? I'm having the same problem and I posted back on January 24th. I have yet to get a response so anything would be helpful. thank you. How do i fix low flow on hot water on a kitchen fa - 4_30_2016_3_59_35_pm.png
Posted on Apr 30, 2016
Low water (hot and old) pressure in kitchen
Following link has troubleshoot walk-thru:
http://waterheatertimer.org/Low-water-pressure.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 30, 2017 | Plumbing
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Jan 08, 2014 | Home
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Oct 16, 2012 | Price Pfister Plumbing
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Apr 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
My Rinnai 24 will only start when I use the the hot water in the kitchen (which is closer to the heater). If I open any of the hot water taps in the bathroom it doesn't work.. I have to start the hot water...
Looks like your recirculation pump might be bad. If your opening a valve close enough to the heater and it comes on, It sounds like it's giving your pressure switch a false reading and allowing it to come one while the farther away you get, it is not enough line pressure to overcome the safety's of the heater.
Sep 28, 2010 | Heating & Cooling
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Nov 14, 2008 | Delta Faucet Plumbing
Plumbing Logo
269 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
