Question about KitchenAid KERA205P Electric Kitchen Range
Convection oven fan is making noise as if hitting fan shroud on start-up and when door is opened.
  • 999 Answers
Either the blades have moved out on the shaft or there is excessive shaft play allowing it to hit when there is not much pressure as during start up and when the door is opened.
Eric
Posted on Jul 16, 2009
How do i make my convection fan turn off when i open the oven door
It sounds like there should be a switch on the door and it is malfunctioning. I would contact the manufacturer as it should be covered under warranty if it is malfunctioning. Especially for a $10,000 oven.
Dec 03, 2014 | Thermador Ovens
Why does my GE Spacesaver Profile, Microwave/Convection Oven, model # JVM1490SD003, in my motorhome, make a clicking noise when I start it up? Sounds like a fan hitting something. The noise goes away
Probably is the fan tapping something. Power it down/DISCONNECT power. pull unit and if there is a cover, remove it. look for the convection fan and see if it free-spins. should find spot where it is hitting and could be adjusted.
Nov 22, 2014 | GE Microwave Ovens
Hobart convection oven
You either have something hitting the convection blower wheel or the bearings in the convection motor are shot.
Feb 17, 2014 | Ovens
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
Why does my Jenn Air convection oven make such a LOUD clattery/ticking noise whenever I use it? I think it must be the fan...can you help?
If you can get at the fan blades without taking anything apart, try to turn the fan blade by using a small screwdriver or even a small wooden skewer. Listen to see if the blades are making contact with either fan cover or the back of the oven or the edges of the convection opening.
Once you determine which blade(s) are making contact, use a sharpie marker to mark those blades you need to correct. That way if the blades are hitting the fan cover, you'll know which ones need to be bent back into shape once the cover is removed.
With the oven turned off, you should be able to remove the circulating fan cover and correctly bend the fan blades back into shape and stop the noise.
Hope you found this very helpful and best regards!
Aug 07, 2009 | Ovens
Convection/microwave makes noise and does not warm food
micro wave oven makes a whirling noise,fan blade may be out off balance and hitting edge of fan mout, slowing flow of air there are no other moving parts in the unit that i'm aware of.
Feb 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Bad fan noise from convection oven
THE ROD THAT HOLDS THE FAN BLADE IN PLACE IS WARPED BENT OR LOSE SOUNDS LIKE YOU BOUGHT IT THAT WAY EASY FIX! ORDER PART AND DO YOURSELF
Nov 16, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Clicking noise of fan on convection
The motor on the fan has to be replaced.The fan is hitting the screen .Hopfully that will fix it .Thank you .
Nov 05, 2008 | Sharp R-1850A Convection/Microwave Oven
LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Mar 27, 2008 | Refrigerators
KitchenAid KERA205P Electric Kitchen Range Logo
1,100 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
