Question about Belkin (F5U307)
Why does the power light no longer stay on?
Why does the power light no longer stay on, on my belkin 7-port USB hub (white / blue model from after I accidently knocked it out, the cord looks fine, the inside where it plugs in looks fine, and now when my computer is off and no devices are on, why isn't the red indicator on, and instead it is NOW only on when the computer is on? How can I get it to stay on always again?
By the way, to prove that before my computer was off, I unplugged the cable from my Mac, and the red indicator stayed on, and now, it won't if the computer isn't on / not in sleep, or if it isn't plugged in. Also, it is plugged in a wall, not a power-serge.
4 Suggested Answers
  • 82 Answers
SOURCE: his speed 7 port USB hub not responding
If it has its own power then it should be OK however if you have 4 devices connected pulling too much load then it wont work - check the devices to see if this is the case. Unplug one at a time and see what happens
Hope this helps
Posted on Aug 21, 2009
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Posted on Jan 10, 2011
  • 747 Answers
SOURCE: Belkin 7 Port Hub has power (red light is on). Has
unplug port and plug port back in and then restart computer.
Posted on Feb 01, 2011
Does the F5U237 work with windows 8.1
It looks like Belkin stop support on certain models of Belkin, even thou you don't state the version model. But if you have a chance, visit this microsoft website which explain that it's not compatible with Windows 8.1
Oct 19, 2014 | Belkin (F5U237) 7-Port USB Hub
What are the different types of usb plugs and ports .
there are 4.
USB 1.1 - the usb port with white central piece.. very slow.
USB 2.0- white central piece.. normally used in desktops and older model laptops.
USB 3.0 - blue colored port with high speed data transfer.
WI USB -wireless USB connection for wireless mouse, keyboard and other devices.
Jun 09, 2014 | Computers & Internet
How to download free driver for belkin F5U237
A driver is not provided by Belkin for this device. It should work with generic usb drivers found in windows or mac.
Feb 24, 2014 | Belkin (F5U237) 7-Port USB Hub
Hello, I have a Belkin 2.0 USB 7-Port Hub, and having trouble with it. When i plug it into my computer, nothing happens, there is no power light and ultimately it seems as though the device is dead. ...
You first need a CAT 5 cable to go to where your internet connection is, such as a modem or another router to your hub. Then you plug another CAT 5 from the hub to your PC. You need to feed internet to the hub then your pc will recieve a connection from the hub. And of course the hub does need power. Hope that's what you were asking.
Mar 09, 2010 | Belkin (F5U237) 7-Port USB Hub
My computer does not recognise my Belkin 7 port hub.
sometimes the power it gets from pc fails but if it is powered alone check outlet or strip
Oct 04, 2009 | Belkin (F5U237) 7-Port USB Hub
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
His speed 7 port USB hub not responding - green light for devices does not stay on and device is not present in Mac window Mac USB ports work directly replugged all connections with no success
Hope this helps
Aug 20, 2009 | Belkin (B5U034) 4-Port USB Hub
WD My Book 1TB not recognised by belkin modem router USB storage
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
My Laptop does not recognize Belkin 7-Port USB Hub(F5U237v1)
Try connecting it to another port or the one on the dock since some devices can be a bit picky about what port they get plugged into.
Mar 15, 2008 | Belkin (F5U237) 7-Port USB Hub
Belkin (F5U307) Logo
57 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
