Question about Video Game Consoles & Games
How do i disconnect charge cord from controller ?
  • 15,935 Answers
Please accept this answer to remove it from the work queue, and re-post with the exact game console you are talking about.
Thanks
Posted on Jul 16, 2009
Solid yellow light on joystick controller will not light up and chair will not move. If we lightly shake the power cord several times that is located at the rear of the chair, problems corrects.
You have a faulty connection in the cord and need it checked. Disconnect battery and check the cord for the charging system for breaks in the cord wires and for a bad connection where it mounts to the transformer. If it is one unit you may need a new charger.
Aug 19, 2016 | Health & Beauty
Tip
How to use a ps3 wireless controller.
<span>Ensure your playstation 3 is properly set up and connected to Plug the power cord for the PS3 wireless controller into one of the usb ports on the front of the PlayStation 3.<span><br /><br /></span><span>Plug the power cord for the PS3 wireless controller into one of the USB ports on the front of the PlayStation 3.<span><br />Plug the other end of the power cord into the access port on the top of your wireless controller.Allow the wireless controller to charge, leaving it plugged into the PlayStation 3 undisturbed for several hours to gain a full charge.Disconnect the PS3 wireless controller from the power cord. Press the PS button to start up the PlayStation 3. The PS button is in the middle of the controller. It is clear and displays the PlayStation logo of a letter P and a letter S molded together into one shape.Use the wireless controller to control the PlayStation 3, exactly as you would have with a corded controller for earlier PlayStations.<br /><span><br /><br /></span></span></span></span>
on Dec 06, 2010 | Sony Playstation 3 (PS3) Console
My computer can't recognize my USB cord
Try another computer, see if it sees it on that one. If it does then you need to delete all the USB ****** bus controllers on your PC. Attacht the usb deviice then reboot the computer and ithe system should fin it.
Aug 12, 2014 | Mach Speed Trio MACH SPEED Eclipse 180G2...
MH-25 is not charging the battery
Check the cords and make sure to disconnect and then reconnect the cords. Try the charger if nothing then try replacing the battery. If the battery is bad the charger will not work. If the battery is replaced and will not charge then replace the charger.
Mar 26, 2013 | Nikon MH-25 Charger NIKON
I charge my mp3 but it doesnt fill up. i charge it for a few hours and it says ok to disconnect. when i try to turn it on, it doesn't.even when i charge it, the icon stays empty.
Check the charging , if you are using USB charging try with another port or with another PC. If the fault still stays then the battery, the main controller within the player or the cord can be a suspect. If there is a small reset button press it down to reset as the last option.
Aug 23, 2011 | Audio Players & Recorders
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
We have rechargeable controllers. They no longer accept a charge. We bought a new battery pack - when you plug in the USB cord from the console to the controller, it says they are fully charged, but when...
it seems like the charge cable isnt charging the pack. have u tried using an alternate charging method like a charge stand? or try on another controller, if it still doesnt work on another controller, its your charge cable.
Apr 11, 2010 | Microsoft Xbox 360 Wireless Controller
My xbox controllers will not charge with the plug in kit. The light turns red, then either immediately green, or it starts to blink red-off-red-off.
I had the same problem. The Battery pack on mine was dead for a long time as i havent touched my Xbox 360 in a while. So
SOLUTION
Step 1. Plug the play and charge cord into the controller
Step 2. If Light turns green within a minute or so, Unplug the play and charge cord and go to Step 1 (Repeating this process until the light stays red on the play and charge cord (3-10 times))
Oct 08, 2009 | Microsoft Xbox 360 Controller
The square, trianle, cirle, and x buttons will not work on my controller while the directional buttons work. My control is fully charged and it does this connect or disconnected from the usb cord.
is it the defalt ps3 controller? if not maybe the buttons are stuck on the inside of the controller. inside of your controller is a rubber base that is under both the D-pad and the X - T - O - S buttons. see if this is bent or thrown off of place. this happened twice ot my controller
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
XBox 360 wireless controller won't connect or charge
Guys, you really need to calm down... I have the same problem like you.
I'll tell you step by step why the Xbox 360 Wireless Controller won't work.
1. The controller will automatically disconnect during the gameplay, and the charging kit won't charge.
Solution: This is true what I'm saying now... Where you guys brought your wireless controllers in the stores, there was a Frequently Asked Questions book inside the kit. It told you about the importance of the charging of your wireless controller, because Microsoft informed that it's VERY important to empty your battery before charging it, because the charging kit will no longer charge your battery, and the same thing happened to me. So, if you have any questions of your wireless controller, then contact me at my gamertag, NussKarte. I'll give you new information how to fix your wireless controller.
Jun 30, 2008 | Microsoft Xbox 360 Wireless Controller
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
