Question about Dryers
Where can I purchase a new dryer filter for my Kennmore 80 Series, Model 110 72802;01?
  • Anonymous Mar 29, 2014
    Series 60 Model 110
  • 5,911 Answers
Go to searspartsdirect.com. If this is the lint screen that inserts in the top panel of a gas dryer, the part number is 8557882. It is priced around $34.
If this is not the part you need, please post back with a more accurate model number. The number you have listed did not cross to any model number I could find. The closest model number I found was 110.72802101. These parts can, however, cross to other models within the same manufactured series.
NOTE:
Appliancepartspros.com carries the same part for $25.
Pcappliancerepair.com carries it for about $27.
Repairclinic.com carries it for about $32.
You can try any other websource you like, but these were the best prices I could find for you.
I hope this helps you.
Posted on Jul 16, 2009
Drain leak
Your spider (diffuser) gasket is pinched or damaged. You can replace it for under $20 unless it is the SP0714 model. If it is a 714 then you have to purchase a new key assembly or a whole new valve. Usually runs about $80-$120.
Aug 26, 2013 | Hayward SAND FILTER, PRO SERIES
I have a used Kenmore Series 80 dryer & the drum stopped turning
Good day,
Not hard to do but check the 2 rear wheels that support the drum and change at the same time if needed. Inspect the belt tensioner as well.
Here's a good tutorial on the belt change.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 15, 2009 | Dryers
Kennmore 80 series dryer.ignitor glows red i hear a click and it goes out motor runs/no heat
Hi, You will need to replace the coils on top of the gas valve. Here is how on most models. If this does not apply to you model, get me a model # and I can look UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
this up for you.
Jul 09, 2009 | Kenmore 63942 Dryer
My 80 Serie Kennmore dryer will not dry my
A simple test you can try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load as you normally would. With the hose removed and the dryer running, the air leaving the exhaust of the dryer should be forceful and warm (about 140 degrees). If the air flow is weak or non-existent, you have a clog INTERNAL to the dryer. You will have to inspect the air blower fan housing and ducting inside the dryer to ensure the blower fan is not obstructed in any way. If the air flow is normal and the clothes dry like they should, you have a clog somewhere in the DUCTING from the point where it leaves the dryer to where it exits your home. You will need to inspect the exhaust ventilation for any clogs or kinks.
If you can see the heating element glowing, you probably don't have a problem with the heating circuitry. If you haven't checked the dryer ventilation recently, now might be a good time to do so. Leaving a dryer in a clogged, or poorly ventilated condition can cause the dryer heating circuits to over heat to the point of failure. In addition, this can also create a fire hazard.
Good Luck!!
Thanks
Jul 08, 2009 | Kenmore Dryers
Kenmore 80 Series Dryer makes loud humming noise while being ran~
good for you a fixya girl. usually, the idler pulley fails. and is a gravy cheap fix. these are great dryer and worth throwing a few bucks at. spin all the pullies and a new belt is a good idea,
AND
How to Replace Kenmore Electric Dryer Idler Pulley How to
LET ME KNOW HOW YOU DID, THE PARTS SHOULD RUN UNDER $20 that's a cool fix !
Jun 09, 2017 | Kenmore Dryers
Something in vent
id screen is on top remove the 2 screws under screen lid remove back cover ..remove the 4 screws holding bottom portion of screen housing over blower pull out and clean ..if screen is in door remove bottom cover (clips top edge press down) remove lint screen remove 2 or 3 screws holding housing to blower
Nov 26, 2008 | Kenmore 62802 Electric Dryer
Dryer does not heat up
my dryer work but it does not give heat ( kennmore 70 series)
model# 10062712101
ser: 1216293
i am trying to get the manual for my dryer from kennmore
Oct 26, 2008 | Zanussi Dryers
Kenmore Dryer - Series 80 - Model 96586200
the brown streaks are from the seals most likely from the front seal ... if your handy it will be an easy fix..
Oct 12, 2008 | Dryers
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Dryers Logo
52 people viewed this question
Top Dryers Experts
