Question about Gateway (4000811) Motherboard
I need gate performance 1400 display adaptor...any idea on how to get my display going?
  • 979 Answers
Good day sir, if you are talking about the onboard vga, you may need to go to CMOS setup and locate the settings in where you need to choose the Onboard vga. there are several options. PCI/AGP/PCIe/onboard, select the onboard one. hope this helps. if you have any more questions feel free to ask. thanks.
Posted on Jul 16, 2009
Change the display name?
Administering a 1400 Series Digital Deskphone
Perform the following steps for each 1400 Series Digital Deskphone:
1. Log into the Avaya Aura Communication Manager administration interface.
2. Perform one of the following steps:
? If you are adding a new extension and want to assign a specific extension number, use
the add station nnnn command, where nnnn is the new extension you want to assign.
? If you are adding a new extension and want to assign the next available extension
number, use the add station next command.
? If you are installing the 1400 Series Digital Deskphone at an existing extension, use the
change station nnnn command, where nnnn is the existing extension you want to
modify.
The Station screen appears.
3. Perform one of the following steps:
? If you are administering a 1408 telephone, type 2410 in the Type field.
? If you are administering a 1416 telephone, type 2420 in the Type field.
4. In the Port field, type the port address.
5. In the Name field, type the name to associate with this telephone. Administering 1400 Series Digital Deskphones
20 Avaya 1400 Series Digital Deskphones Installation and Maintenance Guide
6. Configure the remaining fields on the Station screen pages. Keep in mind the following
information:
? If you are administering a 1408 telephone, the first eight call appearance/feature buttons
displayed on the Station screen are administered on the 1408 telephone. (Since the 1408
telephone is aliased as a 2410 telephone, the Station screen displays 10 call
appearance/feature buttons.) The remaining buttons displayed on the Station screen are
not administered.
? If you are administering a 1416 telephone, the first 16 call appearance/feature buttons
displayed on the Station screen are administered on the 1416 telephone. (Since the 1416
telephone is aliased as a 2420 telephone, the Station screen displays 20 call
not administered.
? If you are administering a 1416 telephone with a DBM32 Button module, the first 16 call
appearance/feature buttons displayed on the Station screen are administered on the
1416 telephone. The remaining eight call appearance/feature buttons displayed on the
Station screen are administered on the first eight buttons of the DBM32 Button module.
The 24 buttons of the EU24 expansion module displayed on the Station screen are
administered for the remaining 24 buttons of the DBM32 Button module.
For more information about administration and features, see:
- Administering Avaya Aura™ Communication Manager, Document Number 03-300509
- Avaya Aura™ Communication Manager Feature Description and Implementation,
Document Number 555-245-205
- Avaya Aura™ Communication Manager Screen Reference, Document Number
03-602878
7. When finished administering this extension, save your changes.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Dec 19, 2014 | Avaya Ip Office 1416 Digital Deskphone -...
I have a M8149 Cinema dispaly 22" and want to connect to late 2009 Mac mini. The monitor came with a strange adaptor set of ADC input to 1x each of usb, 24Pin 92x rows of 8) male ADC, and another plug...
The Apple 22" Cinema display M8149 (ADC) is one that is not compatible.
It might be better to find another brand display to work with your 2009 Mac Mini. The Apple model A1081 is DVI, but for the age (its 8 years old, the lamps are likely dimmer than new...) I would look for a resolution-compatible DVI input display (Dell Ultrasharp, etc..).
Jul 22, 2017 | Apple Computers & Internet
Liftgate won't open automatically
To open the lift gate manually, use the door unlock switch located on the drivers door. This should unlock the lift gate as well. Go to the lift gate and lift the handle to open the rear gate.
Your power lift gate is computer controlled. Sometimes there will be a faulty input sensor or part that will show the incorrect data to the computer, therefore the computer will not go through its normal functions.
In most cases its the problem of lift gate latch assembly.
To get it tested and confirmed there is a troubleshoot guide provided by the service center. To perform this troubleshooting guide you will require a scan tool to diagnose the exact problem.
the troubleshooting procedure is as follows:---
Please use the following information below when diagnosing an inoperative lift gate. Disconnect the connector at the lift gate latch assembly. With the lift gate latch connector disconnected, the 3 signals for the ratchet, pawl, and the sector should be inactive on the scan tool.
Install a 3A fused jumper wire between each signal circuit terminal (for the pawl, sector, and ratchet) and the ground circuit terminal 2. Monitor the scan tool as each individual circuit is jumped to ground, the scan tool should read "active".
If either tests above fails, check the wiring for the signal circuits, low reference circuit, or try a power lift gate control module from a known good vehicle. If both tests above pass, monitor the internal switch inputs in the lift gate latch assembly for proper operation.
3. A) with the lift gate in the open position, the ratchet and the pawl should read "active" and the sector should read "inactive"
B) With the lift gate in the secondary latched position, the pawl should read "Inactive" and the ratchet and sector should read "active"
C) With the lift gate fully closed, the pawl, ratchet, and the sector should all read "inactive".
4.If one of the internal lift gate latch assembly switch inputs are not reading correctly in one of the positions above and the vehicles passes test 1 and 2 above. Replace the lift gate latch assembly.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
This should help you.Thanks.Helpmech.
Dec 04, 2010 | 2006 Cadillac SRX
Lamar 1400 message "Perform Scheduled
My Lamar 1400 says" L 14 scheduled maintenance" and will not run.
Nov 02, 2010 | Startrac Fitness Products Lamar L1400...
My toshiba satellite m30s350 model nvidia geforce display sam time work and some time not working pls sir gate me solition
  1. Go to NVIDIA Gforce web site, select your product, download the latest driver. Upgrade the old driver. Restart your PC.
  2. If still not working, remove the Graphics card, clean properly and reinstall.
  3. Go to device manager check harware performance.
Aug 20, 2010 | Toshiba Satellite M30-S350 Notebook
I need of a turbo waste gate on a 7.3 liter
Yes it will hurt the performance if yo do anything wire the waste gate shut. however the waste gate is on the inside of the turbo unless you have a special turbo that is not stock.
Sep 30, 2009 | 1997 Ford F250 SuperCab
USE LAPTOP ON TV & LAPTOP AT THE SAME TIME
dear sir
yes i can help u strongly... first of all u have to turn of laptop then connect yr laptop and tv then turn laptop on now when windows appeair. laptop screen has icon and other has plane wallpaper so now go to display propaties ( click on desktop>go to propaties>setting> now it's show's 2 monitor screen on display screen click in inditeficate... how it's show "Expand display " somthing like that just remove select earrow now click apply... if it's not worked go to advance then go to adaptor setting and find display setting and select "CLONE" it's male both laptop and tv screen as same...it's help u...:)
Thanks
please vote
jo_chinmay
Oct 06, 2008 | Toshiba P000347580 - Satellite 1400&2400...
Display console
There is a switch in the lift gate latch that closes when the gate is closed and turns off the light, this switch is defective, replace it and the light will go off.
Sep 16, 2008 | 2004 Jeep Grand Cherokee
Belkin USB/adaptor
Google Franson GPS GATE this little software utility is what you need
Mar 31, 2007 | Belkin USB/Serial Portable Adapter...
Gateway (4000811) Motherboard Logo
124 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
