Jbl sub135 started motorboating, now doesnt play at all,led stays in standby mode, no sound except occasional crakling
3 Suggested Answers
  • 5 Answers
SOURCE: jbl sub 135 motorboating b4
Sounds like a possible ground loop problem. Are there anyother cables running on top or along side the sub cable? Also, make sure there is no other remotes or electronics on top of the sub itself.
Posted on Mar 04, 2009
  • 5 Answers
Turning the unit on without any input signal, the speaker did the pop and scratching sound. I found on the limiter board ( small pc board on the main input pc board) that there is a wire jumper on the back side of that had a cold solder joint. You will have to clean up the glue that was used to hold the wire on the back side of the board. I just replaced the wire with new one.
Look at the +15vdc off of Q117, I moved it to the left side of the pc board and added a heat sink to the unit. The 1 watt resistor created some cold solder joints that you will have to check.
hope this helps
Posted on Jul 18, 2009
JBL-SUB135S please i need User Manual
As it is also sold as part of this system, Cinema ProPack 600, this manual should suffice.
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/OwnersManual/JBL%20CPP600%20OM%20(final).pdf
Page 37 gets into it. That's all there is to know.
There's not a lot going on in a vanilla self-powered sub. You seen one, you've seen them all.
Jun 28, 2011 | JBL Audio Players & Recorders
Everything works except for mp3 when i plug it in. doesnt even say aux on screen
Just figured this out !
1) You have to be in 'Standby' mode - press (SRC) until it shows standby.
2). Press and hold 'Menu' button.
3). Using the joystick - move it left or right until it shows 'AUX' 'OFF'.
4). Move joystick up or down until it shows 'AUX ON1'.
It should now work ! - This is on P.22 of the manual - but it actually starts on page 19 where it describes 'Standby' mode.
Aug 03, 2010 | Kenwood KDC-MP205 CD Player
How to connect the wires of jbl sub 145
what kind of conections do you have on the back of the sub you should either have RCA connections or just one RCA connection or a place for speaker wire to plug directly into it. IF you have RCA connections in back i would use those they will connect directly to your system if your system had and a sub pre out on it read your manual and follow those instructions as well it will help
Oct 27, 2009 | JBL escXcite System
Harman Kardon AVR325 stays in standby mode
Was a solution ever found for this? I have almost the same problem, except that mine makes a horrible sound through the speakers before it shuts off. However, after an attempt or two, mine usually starts working and sounds fine (I love how this thing sounds!). It seems to happen more when I've let it sit for a week or two. When I use it regularly, it usually works fine. It's almost like it knows when I'm about to give in and replace it... because it will start working again! Maybe I just need to make an effort to use it more....
Mar 22, 2009 | Harman Kardon AVR 325 Receiver
Jbl sub 135 motorboating b4 warm up JBL sub135 I never heard it called motorboating, but that is a good description of the sound, It's like the sub is trying to output sounds which are not in its range...
hope this helps
Feb 19, 2009 | Audio Players & Recorders
Jbl amp kiskcs in and out
Something inside the amp is busted.... stop hitting it... and replace it.
May 18, 2008 | JBL BP1200.1 Car Audio Amplifier
When i press power nothing happens except the standby light just blinks and doesnt stop.
What is the make and model number of your set? I can help you but I need that info, So I know where to start.
Jan 23, 2008 | Televison & Video
JBL PB12 standby WAY too sensative
It sounds like there are failing parts in the amp and possibly in the power supply sections. You should contact JBL to find out their service rep in your area.
http://www.jblpro.com/contact/form_dir.html
This unit will not be cheap to service. But, you can start by investigating to know where you are going with it.
Jerry G.
Aug 12, 2007 | JBL PB12 Subwoofer
No sound what so ever
it died and the parts aren't available, same problem here, even took it to an authorized outlet, parts aren't available
Jan 29, 2007 | JBL PB12 Subwoofer
179 people viewed this question
 Grubhead
Grubhead
