Acer eRecovery Management starts on boot or reboot.
  • 335 Answers
Somehow, e-recovery is being triggered at boot time. click start-programs-startup, and remove e-recovery from the startup folder if it is present. If not, click start-run, type in msconfig - a window will appear. Go to the startup tab and uncheck any items with e-recovery in the name. do not delete all acer items. Tread lightly here. Anyhow, if that doesn't do it, remove the acer items one by one in msconfig and reboot after each change until it's right. Don't make a habit of using msconfig too often though.
Hope this helps!
Posted on Aug 09, 2009
5 Suggested Answers
  • 11 Answers
SOURCE: Acer laptop restarts repeatedly to acer erecovery management environment
did you reformat the hard drive first?if not then you needed to ensure that you selected 'repair' first.
Posted on Jun 29, 2008
sandrew
  • 2961 Answers
SOURCE: ACER eRecovery management
go here and select empower and your operating system
http://support.acer-euro.com/drivers/notebook/as_5610.html
Posted on Aug 31, 2008
  • 489 Answers
SOURCE: Acer erecovery management
i think your back - up broken dow.  its a known acer problem when the system using for 1 year or more
Posted on May 27, 2009
envision507
  • 30 Answers
SOURCE: forgotten password on my Acer eRecovery Management
If you fully formatted the hard drive then most probably you have cleaned the PQservice division which might had recovery data; you can check this with the help of Computer Management console in Windows. It is in Windowssystem32compmgmt.msc. Also check the Disk Management and see what partitions you still have. Acer eRecovery Management won’t work if there is no default partition i.e. There should be E or D partition in order to run it.
Try www.download.com Here you might find your required software or else you have to ask the supplier to fix this problem for you. Hope this helps!
Posted on Sep 07, 2009
How to tacke my aspire 5250 back to factory settings
*******All of your data WILL be lost during this process so back everything up first**********
1. Power on the machine.
2. At the ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery. The window of opportunity is very small, so this may take a few attempts.
3. Once eRecovery has loaded, click "Restore to Factory Default Settings" (the password is six zeros, 0.0.0.0.0.0.).
4. Click "OK" to continue.
5. From here, the eRecovery process will update all the data on the C: drive and restore the factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit.
OR
1. Reboot, and press F8.
2. Select Repair.
3. Select Reinstall Windows and follow prompts.
OR
Running System Recovery from Windows
1. Click Start>All Programs>Acer Empowering Technology.
2. Select Acer eRecovery Management.
3. Select Restore (bottom of eRecovery screen).
4. Select Restore system to factory default (the password is six zeros, 0.0.0.0.0.0.).
5. Select Yes then Next, the system will reboot and start the recovery.
Jul 04, 2014 | Dell Latitude D400 Notebook
Aspire one d257-13473 wont factory reset
Windows key > All programs >Acer Empowering Technology>eRecovery management>Restore>Factory(Top of list)..
Or
If computer will not boot.
Tune computer ON
When Acer splash is on screen hold Alt and keep pressing F10...
Select factory from top of list.
You will need a password , the default is "000000" (Six zeros).
Recommend you use the first option if you can...
***This will erase all your unsaved data!***
Or
Or
2. Select Repair.
Dec 06, 2013 | Acer Aspire One D257-13473 Netbook
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
Aug 26, 2013 | Acer Veriton Z290G Desktop Computer
Acer aspire one reset to factory settings
Try alt+F10 when windows boot.
else try restart your computer start tapping F8 once you see the advance boot options..go to repair my computer..select the language..then enter your user name and password..in recovery options go to factory image recovery.
Sep 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
Need to reset factory settings to wipe laptop clean but dont have a disc
hi
there is two ways to do it.
Laptop Recovery Instructions
If you cant boot into windows
2. At the white ACER BIOS screen, hold the "Alt" key and press the "F10" key
and restore a fully functional factory image (approximately 10 minutes).
If you can boot into windows
Click "START"
All Programs
Acer/ Packard Bell/ E-machine recovery
Select "Recovery management"
Click "Restore"
Click "Fully restore to factory default"
NB: This process takes about 15 to 20 min
Jun 15, 2011 | Acer Computers & Internet
Restore acer one to factory settings
Download this pdf it gives full instructions for restoring XP.
http://www.acerpanam.com/...
Using Acer eRecovery Management
You can launch Acer eRecovery Management in a number of ways:
• By pressing the hotkey <Alt> + <F10> during the boot-up process, or at any
time when you are running Microsoftâ® Windowsâ®.
• From the Start menu, go to Start > (All) Programs > Empowering
Technology > Acer eRecovery Management.
Jan 19, 2010 | Acer Aspire One A150-1006 Notebook
How can i reformat my laptop on CD acer aspire 3000
Acer eRecovery Management requires a password to activate. The default password is six zeros (0s).
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
OR
From the Start menu, go to Start > (All) Programs > Empowering Technology > Acer eRecovery Management.
Or try this By clicking on the Empowering Technology icon from your desktop, or pressing the key to launch the Empowering Technology user interface. Select the Acer eRecovery Management icon.
Oct 11, 2009 | Acer Aspire 3000 Notebook
Restore back to factory settings
If the computer will boot into windows you can choose this option from the Acer E-Recovery management software.  If it will not then use alt+f10 during the boot.
Dec 11, 2008 | Acer Aspire 5610-4648 Notebook
Acer laptop restore factory settings?
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
Oct 19, 2008 | Acer Aspire 5050-3242 Notebook
Acer 5050 laptop
I assume from the question that you want to restore your computer to factory default - like the day you bought it. Warning - this process will wipe out all you data unless you back it up to an external drive or DVD.
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of selecting Restore System to Factory Default.
Computers & Internet Logo
1,976 people viewed this question
David Payne
David Payne
