SOURCE: charging alien battery?
if you had given for servicing anywhere in any other shops other than the authorized service centres, they might have changed the batteyr. try top get that problem solved.
SOURCE: Not able to charge the battery
As per Sony, if you are getting this message, it's a concern.
This message usually appears, if you are using a Battery other than Sony's.Make sure you are using Original Sony's charger. Try to use some other Charger and Battery.
If problem persists, you need to send the unit for repair. More likely, it's a firmware issue. I have hardly seen any Charge / Battery issue.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
