Question about Lexmark X83 All-In-One InkJet Printer
MODEL 4427-001
I cannot get rid of the "cover open" mesage on the display screen on the printer itself, it will not allow me to print.
Yes this is an hardware issue and in this printer need to be replaced onec it is reset to factory defaults
Posted on Dec 14, 2007
0 characters
3 Points
Printhead error
A firmware update for your model addresses the "printhead error" on your printer. First, get rid of error message on the display screen to successfully update your printer firmware.Open the cover to remove the printhead and tanks (if installed). Note: Carrier will come to the center automatically with this error message as the cover is opened.
Then proceed with the firmware update. Please visit the Lexmark website at to download and install the firmware update.
Should you need further assistance, please don't hesitate to contact Lexmark Technical Support Center.
Mar 10, 2012 | Lexmark Interpret S405 Wireless All-in-One...
My printer keeps telling me that i have a system error. Remover paper jam then press start but nothing happens. Help
Where does this "system error" message appear? On your printer display or on your computer screen? Try to remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges. Then load some paper. Try to print again and see if the error appears again.
May 05, 2011 | Lexmark X125M All-In-One Printer
The printer (Lexmark X5340) display "cover open"
Short of slamming the cover closed there is a small tab that tells if it is open or closed. It should be located on the lower right hand corner. Once you find it just put a small piece of paper there or plastic and you should have no more problems.
Mar 30, 2011 | Lexmark Printers & Copiers
How i remove the inkjet from the printer
Here's the link to the Lexmark website on how to view the Lexmark Z645 printer User's Guide on your computer. You might want to scroll down to Maintenance or Maintaining the printer for the instructions on how to replace the cartridges. If you won't be able to view it, try the steps below.
Make sure the printer is on. Lift the cover open. When the carrier positions itself in the center, open the latch. Reload new cartridges then close the cover.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps.
Leave a comment if you still need more assistance. Thanks.
Jun 19, 2010 | Lexmark Z645 InkJet Photo Printer
Lexmark x3470 printer says "cover open" and it will not do anything. Curtis
Try these as I found them from Lexmark's website
Solution What you will see
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
Possible cause of the error
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to do
Take the following steps to try to determine if there is a hardware fault:
Steps Actions 1 Remove and replace the cartridges from the printer. 2 Disconnect the power cable and the USB cable. 3 Check that the power cable is plugged directly into a wall socket. 4 Reconnect the power cable. 5 Close the printer cover. 6 If the error persists, please contact Lexmark Technical Support for further instructions.
Nov 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470
Try looking around the edges of the cover or in the hinge area for a switch that may be stuck. Most covers have a switch to indicate that the cover is open, the cover may not be seated properly or the switch may be stuck in the open position.
Aug 30, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 has cover open in display will not do anything now
you need to open cover and undo and remove the grey cover inside the printer as there is a switch at back of machine which has *** off
Sep 29, 2008 | Lexmark MFP-X3470 All-In-One InkJet...
Cover open message
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Jul 20, 2008 | Lexmark X3480 All-In-One Printer
Cover open
see your printer cover for broken.
Mar 18, 2008 | Lexmark X3470 All-In-One InkJet Printer
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Lexmark X83 All-In-One InkJet Printer Logo
Top Lexmark Printers & Copiers Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Printer and Copier Expert? Answer questions, earn points and help others
