Question about Nikon D90 Digital Camera with 18-105mm lens
WILL THIS MODEL JELL WELL WITH THE NIKON 50mm LENSES (NORMAL) & OTHER BRANDS OF 50mm LENSES (NORMAL) THAT IS WITH NIKON D90 DSLR
  • 146 Answers
The Nikon D90 works well with the Nikon AF 50mm lenses and most other brand Nikon fit AF lenses. If they are not AF you will lose autofocus and metering.
Do you know that on the D90 the lens becomes a 75mm but the aperture stays the same, so for instance the 50mm f/1.8 is a 75mm f/1.8.
Posted on Jul 16, 2009
Is the Tamron AF08N700 auto focus with the D90?
Good morning. You have likely already gotten an answer to this, but yes, it will.
Unlike less expensive models such as the D40, D60, D3000 and D5000, the D90 has a built in autofocus motor, which means that all Nikon F-mount autofocus-lenses (except two for the rare Nikon F3AF) can be used in autofocus mode for all newer generation autofocus lenses like the Tamron 200-800. However, you may want to look around a bit, as Tamron has come out with a new 150-600 lens that is simply terrific (I know, I own one) and the Big Sig from Sigma is equally great.
FYI
Good luck.
Dec 05, 2015 | Nikon DSLR D90 Digital Camera
How much is nikon d90 in the philippines price
Hi alvinearlaca,
Nikon D90 DSLR Camera Price and Features:
The Nikon D90 is a 12.3 megapixel digital single-lens reflex (DSLR) camera that offers live view capability and automatic correction of lateral chromatic aberration.
It is known as the first DSLR to feature HD 720p video recording with mono sound at 24 frames per second. It replaces the Nikon D80 and positions itself between the company's entry-level and professional DSLR models.
We have here the price (in Philippine peso) of Nikon D90 digital camera.
Nikon D90 Digital Camera Price (body only) in the Philippines: Around Php 36,000 - Php 37,000.
Nikon D90 Digital Camera Price (with Nikkor AF-S DX 18-105mm f/3.5-5.6G ED VR lens) in the Philippines: Around Php 52,000 - Php 53,000
Hope it helps.
Thank You for using Fixya.
Sep 09, 2011 | Nikon D90 Digital Camera with 18-105mm...
What is best lens to photograph kids for headshots and 3/4 to full body shots with the nikon D90? the best lens for between $300-$500?
One of the best portrait lenses for the Nikon D90 is the Nikkor 50mm f/1.8 lens which can be found here: http://www.amazon.com/Nikon-50mm-Nikkor-Digital-Cameras/dp/B00005LEN4/ref=sr_1_1?ie=UTF8&qid=1298955171&sr=8-1. At low f-stops the lens blurs the background beautifully and will really make the pictures of the kids pop. An added plus is that it can take great photographs in low-light situations. It only costs $125 as well.
Jan 28, 2011 | Nikon DSLR D90 Digital Camera
I am trying to mount the AF f/1.8D 50mm lense on my Nikon D90- I do not here the click sound - when I turn on the camera, in the view finder I see F-- flashing all the time in any mode. Can you help me...
This particular lens is known to be a tight fit, especially when new. Most likely you just need to turn the lens a hair more and a little bit harder than you normally would in order to have it "click" home.
Dec 18, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
I have a D90 Nikon, I mounted my Nikkor 50mm 1.8d
Make sure you set the aperture ring on the lens to its smallest setting (largest f/number) and lock it. Without doing so, the lens will not communicate properly with the camera and thus you will not get the autofocusing.
May 30, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
Does nikon 50 mm f1.8 works in Nikon d90
Yes, you won't get 3D matrix metering or TTL distance
though. Check here for more info:
http://www.nikonians.org/nikon/slr-lens.html
Dec 08, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
WHICH LENS WILL GIVE THE SAME RESULT OF 50 MM LENS IN FILM MODEL
To figure the equivalent coverage comparable to a film camera, multiply the number of mm by 1.5. Example: a 50mm lens will be like a 75mm lens on a digital camera.
Sep 08, 2009 | Nikon DSLR D90 Digital Camera
Nikon 50mm 1.8 lens error message
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Jun 25, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Can't autofocus Nikon 50mm f1.8 lens
The lens has an autofocus motor, but because it is an older model, it will not autofocus for the D40(x), D60, or D5000, which have more stripped down components. I advise you exchange the lens for the newer model, or return the D5000 and get the D90 for just a bit more.
Jun 11, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon D90 Digital Camera with 18-105mm lens Logo
452 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
