Question about Sub-Zero 680 / F
Where are the coils on a sub zero 680? Vacuum condenser signal
Where are the coils on a sub zero 680? I wanted to clean them. Also, the vacuum condenser signal is flashing. What does this mean?
  • 55 Answers
Hello.
On the top of your unit there is a grill. Open both door and look at the lip under the grill. Remove these four screws. Now, pull on the top of the grill. You will notice that it is held on by two springs. Unhook those springs and set the cover aside. The coils are on the right hand side. Use a vacuum with the soft brush attachment to clean them and avoid damaging the airflow. Also, check the fan on the other side of the coils to make sure it is running.
Posted on Jul 16, 2009
Vacuum condenser keeps flashing
Clean the coils, usually at the bottom of the unit, remove the cover and use a vacuum and a bottle brush and clean away, use a crevice tool on the vac. hose but do not force it between the coils.
Jun 26, 2011 | Sub-Zero 650 / O Bottom Freezer...
The Vacuum Condenser message has come on. Where is the Condenser in my Sub Zero fridge Problem ?
The condenser is the coil on the outside of the unit that rejects the heat. most Sub zeros I have serviced had top mounted compressors and condenser coils .just find the compressor and the coil. Be careful of the fan. they just want you to check on it
Jun 25, 2011 | Refrigerators
Sub-Zero 680/F The fridge is flashing "service"
Not filter but condenser coil thathe is next to compressor. Clean it out then check unit operation
Jan 26, 2018 | Sub-Zero 680 / F
My Sub-Zero side-byside freezer is at 35 degrees and says "vacuum condenser". What does it mean and what can I do?
At the top or bottom of your unit you have a removable panel that covers your compressor and condenser, you should hear a fan, that is your condenser fan, those coils need to be cleaned with a vacuum or dryer brush
Sep 03, 2010 | Sub-Zero Refrigerators
Code vacuum condensor
clean your condenser coils. located in the top part of the fridge. unplug the unit before service. vaccum the condenser. if after 2 or 3 weeks the vaccum condenser comeback is really posible that you have an evaporator freon leak. in the fridge side
Mar 29, 2010 | Sub-Zero Bottom Freezer Refrigerator
We have a flashing vacuum condenser message on our screen -- what does this mean?
It probably means that your condenser coils are dirty and need to be cleaned up. The condenser coils are the copper tubes in the back of the machine next to the condenser fan. If just vacuuming them up doesn't sufficiently clean them then you may want to get some coil cleaner from your local hardware store or whoever sold you the refrigerator.
If the condenser coils are already clean then you may not have enough airflow. Be sure you have 4 to 8 inches of free space behind the unit to provide adequate airflow.
Mar 13, 2010 | Sub-Zero 642
I need to vacuum the condenser in a sub zero,
The condenser coil is located behind the cover on top of the two doors and when you take it off you see the coils that look like a radiator (fins and copper pipes) ,turn of the refrigerator and with a brush and a vacuum clean the coil very carefully and don't push to hard against the fins.
Aug 24, 2009 | Refrigerators
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 680 - vacuum condensor message won't go away.
You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that should clear the fault code.
Aug 16, 2009 | Sub-Zero 632 / S
Refrigerators Logo
745 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
