Question about Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle
It will not fire any ammo.
They keep jamming in the barrell. The gun has not been used in years. I now have grandsons who would like to use it. It looks new.
    Problem Solver:
  • 17 Answers
Wont just be the barrel.
The whole thing will need to be stripped right down and cleaned including the piston, chamber and mainspring.
You may even have a broken mainspring
RobbieP
BSA owners Group
Posted on Nov 19, 2009
  • 86 Answers
Try cleaning out the barrel there might be some build up in there
Posted on Jul 29, 2009
Best recommended bullet weights for a 1:9 twist 16 inch barrel in 5.56
Head to Walmart and buy whatever's cheapest. Just because some other "expert" tells you something there's no reason you should fall for that dreg and there's no reason to pass it on. Your gun will fire *any* common 5.56 ammo. Buy whatever's cheapest and that will run reliably in your gun. You aren't sniping terrorists at 1,000 yards.
Oct 08, 2016 | Optics
My gun works but has been stored for about 30 years. What maintenance should I perform?
what sort of gun is it ( vital information)
if it is a gun that uses live ammo , the a clean barrel bore is a must as any rust or obstruction will have it explode in your face
if it an air rifle , the bore has to be clean and rust free or the slugs will jam in the barrel
What you should be doing is pulling it completely down and cleaning , oiling and replacing any unserviceable parts
if you do not know how to do that then a gunsmith is the answer
May 26, 2016 | Miscellaneous
Modern ammo for it- 32 Colt short
Contact a local gun lovers shop.
May 18, 2016 | Optics
Is safe to shot modern ammo in this gun & what kind
if the weapon is not designed for high power ammo then the possibility that the gun will explode in your face is very real
Jan 31, 2016 | Optics
Smith wesson problems MP15/223 cal.
How many rounds are you capping off on one trip to to the range? If it a 100 rounds or more, your weapon will retain a small amount more burnt powder and the lacquer coating on the cartridges, but it really is hardly noticeable, but still need to keep your weapon clean no matter if you are using copper. Made in USA. The mp (military /police) is a cheap version of that rifle with no cover over the breech, and no clambering damper. Still worth 5-6 hundred new.. The firing pin cruds up, and if it was fired before you got it and wasn't cleaned that would do it. If it fires, it will jam! Try the dirty gun stenerio, not a bad choice, Colt or Armalite get a little more respect and higher price. Never give up on a 15 , parts are available and reasonable price, and ther are a million upgrades , but careful not to find that you have made it too heavy
Apr 20, 2017 | Watches
Marlin rifle model 795 jams intermittently
It takes about 250 rounds to break in a gun. Try some hotter ammo and see if the problem disappears, if so, call Marlin and ask them for their solution if you want to keep using Federal, you might want to try some Remington standard velocity target, it is very accurate in most guns.
I would shoot it for at least 500 rounds and clean it from powder debris in chamber and receiver bolt and trigger group and try it again, however don't hesitate to get a hold of Marlin, they are nice folks.
Feb 12, 2013 | Marlin 795 Semi-Automatic -22LR Rimfire...
Wenchester 1300 pump shoot one time then jams
This is the cars and trucks section, but I will try to help. Make sure your barrel is fully turned into the receiver. Check for cleaning pads jammed into a moving part. Make sure your shell length is correct for the gun.
Try different Factory ammo, reloads may be deformed. Bring some of its' used casings along to a Gunsmith, he/she may be able to look at them and see machine marks from how the firing chamber is operating.
I hope my solution is helpful, please rate.
Nov 06, 2012 | Cars & Trucks
I have a 243 cal single shot that snaped when fired. Tried different ammo. still misfires
Firing pin is worn. It may make a slight dent in the primer, but not quite enough to press against the anvil inside of the primer, hence the misfiring
Talk to a gunsmith to see if he has any spares, or has the ability to repair the firing pin.
Oct 03, 2012 | Harrington & Richardson H&R Sportster in...
My 8 year old grandson brought home his ner n-strike raider CS-35 and without reading instructions promptly shoved the drum magazine directly into the main gun body without first inserting the drum...
unscrew the entier gun... all nerf guns are screwed together. you can practically cut the gun in half by unscrewing it. just make sure to put everything back how you found it. good luck to you.
Mar 29, 2011 | Nerf Toys
It will not fire and I have put the correct ammo in the gun,and I have loaded it the correct way and it will still not fire
Check the end of your ammo. See if there is a dent in it. It should strike the shell hard and leave a very good indention if not,the spring or firing pin is bad....you are using new ammo right?
Dec 21, 2009 | Sport & Outdoor - Others
Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle Logo
184 people viewed this question
Top Crosman Boating Experts
Ted Maxwell
Neil
Level 1 Expert
yobo007
yobo007
Are you a Crosman Boating Expert? Answer questions, earn points and help others
