Question about Onkyo TX-SR605 Receiver
Onkio TX-SR500 don't leave stand-by
My amplificator leave on "stand-by" mode. Even if a try to close or open it, it stay "stand-by".
    Problem Solver:
  • 5 Answers
Re: Onkio TX-SR500 don't leave stand-by
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} With the unit unplugged, remove the top cover and use an ohmeter to check the 10 power transistors on the large heat sink; Q6050 thru 54 and Q6060 thru 64. If you find blown transistors (R<1 ohm from E to C) you'll need to replace them. After removing the shorted transistors, also check the associated large ceramic current sharing resistors, R6100 thru 04 next to the output transistors. These are dual 0.22 ohm, 2W resistors that typically fail open if overstressed. These are both common failures resulting from overloading the speaker outputs that will cause the proctection circuit to shut down the power supply at turn on. Good luck.
Posted on May 07, 2009
0 characters
3 Points
My TX-SR500 rear speakers stopped working,I tested each speaker using the channel select to optimize the rear speakers but the left and right front speakers were adjusting instead and I know I have the...
And you don't think the speakers are wired wrong. Re-investigate or reposition the speakers you THINK are Front to the Rear and go on from there.
Jul 31, 2011 | Onkyo TX-SR500 Receiver
Receiver goes to stand by when turned on. All components and speakers disconnected and still goes to stand by. Any suggestions?
This is most likely a "protect" mode. A problem has been detected and the unit shuts down to prevent further damage. The most common cause of this are defective output transistors. Plan on a parts cost of $25-$40 for this repair.
Jun 15, 2010 | Onkyo TX-SR500 Receiver
Hi, after i turn the power on and then press the stand-by button, it clicks off to stand-by mode instantly. This is an Onkyo TX-SR500
This indicates that the system is going into protect mode. First disconnect all speaker wires (with the power cable disconnected). Then turn the unit on and see if it sill shuts aff ofter a few seconds. If it does not, then you have a problem with the speakers or speaker wires. inspect the wires at both ends for frayed strands that may touch. If that all lookd good, plu the speakers in, one at a time, until the problem reappears. Be sure to turn the sytem off before plugging in any speaker just to prevent any accidental short which could be catastrophic. If the system goes into protect mode with all speakers disconnected, you probably have a shorted output transistor.
Apr 05, 2010 | Onkyo TX-SR500 Receiver
No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Jun 12, 2009 | Onkyo TX-DS696 Receiver
Trying to connect cable box....
You should be able to pick any open audio device unless it says pre-amp only. If your manual shows a connection for a CD player or similar device it should support the cable box.
Good luck and thanks for using FixYa
Mar 17, 2009 | Onkyo TX-SR500 Receiver
My Onkyo TX-SR500 receiver stays in standy/on mode.
It may be your amplifier protection circuitry is being activated and shutting down automatically. This is usually caused by a faulty output transistor in one or more of the channels. I recently repaired my Onkyo TX-SR500 which had this problem.
Using a multimeter on ohms check between C and E on each of the ten output transistors. I found Q6051 and Q6061 to be short cct on all pins. Once you have located the faulty channels check the adjacent components for open or short cct.
I replaced the following components,
Q6051 (2SD1047)
Q6061 (2SB817)
R6091 (2.2ohm fusible)
R6081 (2.2ohm fusible)
R6101 2x 0.22ohm 2W
Q6031 (2SD2061)
The amplifier now works perfectly, cost of the parts is about $15-$20.
If you don't feel confident doing this yourself just find a friend or tech who can do it for you.
Jan 11, 2009 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 loosing settings
Turning any receiver off will erase the settings - there is no backup battery (Onkyo uses Battery Free Memory Backup) and the length of time depends on the capacitor charge. Why not just leave the receiver plugged in? Stand-by mode uses a negligible amount of power - enough to keep the capacitors charged and the LED on the front panel on.
Jan 27, 2008 | Onkyo TX-SR500 Receiver
Unit no longer powers up after shorting the switched plug in back of unti
you most likely fried a circuit board trace on the power supply
Dec 25, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR605 Receiver Logo
254 people viewed this question
Top Onkyo Audio & Video Receivers Experts
 Mike M
Mike M
D. E. Hev
Are you an Onkyo Audio and Video Receiver Expert? Answer questions, earn points and help others
