Question about Cell Phones
I lost my instruction manual and i forgot what keys to press to access my messages and the menu.
  • 322 Answers
Go to manuals.com and get the adobe format for your manual.
Posted on Jul 16, 2009
OSD Locks Automatically
Power off your computer and then remove the monitor cable from the port on the back side of the computer case.
Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed.
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message.
Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen.
Use the arrow buttons to navigate through the main menu options.
Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
hope this helps
Jun 07, 2012 | HP Computers & Internet
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
How do I get my messages from the answering machine ? What do I need to key in ?
If you are using the handset, press Menu and scroll down to the line Answer Machine with the up/down arrows. Then press the left soft key twice (Select answering machine and then play new messages). The left soft key is above the Talk button. Press End to stop the play back of messages. When there are no new messages, the above will play all messages.
If you want to access the messages from another phone, you first need to change the Master PIN from the one it shipped with and set up remote access. You do this from the handset.
To change the Master PIN, press Menu, scroll to Advanced Set and press the left soft key. Then scroll to change PIN and press the left soft key. Enter the original PIN (or the current PIN) and press the left soft key. Then enter the new PIN followed by pressing the left soft key twice. You will hear a tone and see New PIN Stored on the screen. If you do not enter the correct PIN above, the screen will return to the previous menu. The PIN from the manufacturer is 0000.
For remote access, press Menu, go to Answer Machine and press the left soft key. Then scroll to Ans. Settings and press the left soft key. Scroll to Remote access and press the left soft key. Use the up and down arrows to select Activated then press the left soft key again.
Once these are set, call your phone number and when the machine picks up press #. Within 8 seconds, enter the PIN. An error tone will play if you do not enter the correct code; try again. The unit will hang up if the PIN isn't entered in 8 seconds. All new messages will play. Press 1 to replay a message (or go to the previous message), 2 to play all messages, 3 to advance to the next message, 4 to delete a message.
The manual is available here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=ID9371B/37&scy=us&slg=en .
I hope this helps.
Jan 19, 2011 | Philips ID9371B DECT telephone
How to change voice message on a v-tech phone model cs6229-3 cannot change voice message-lost instructions manuel.(717)866-9262
Press Menu/Select button while phone is not in use.
Press Menuu/Select button to choose Ans System.
Press arrow up or arrow down to choose Ans System Setup, press Menu/Select button.
Press arrow up or arrow down to choose Announcement, press Menu/Select button.
You will hear the prompt "To play press 2, to record press 7. Press 7.
You will hear the prompt "Record after the tone, press 5 when you are done".
You will hear a tone, record your greeting, speaking toward the microphone. Press 5 to end recording.
Your new greeting will be played back automatically, press 5 to end replay, press 2 to start replay again, or press 7 to record again.
Minimum message length- 2 sec
Maximum message length- 90 sec
Below is a link where you can download a copy of the User manual.
http://safemanuals.com/user-guide-instructions-owner-manual/VTECH/CS6229-3-Pre_E
Dec 12, 2010 | Vtech 5.8GHz Analog Cordless Phone
Lost my internet, wont load so need settings please
  • Navigate to your cellular provider's website or call its customer service line. Access the "Support" section of the website or ask for the technical support division. Find the "Access Point," "MMS" and "Wap Gateway" settings and write them down.Power on the HTC phone and then press the soft key on the left side to bring up the main menu screen. Scroll down through the menu and highlight the "Settings" option. Press the square button at the center of the phone to access the settings menu.Choose the "Connections" option from the settings menu. Scroll down through the new list that will appear and choose "GPRS." Highlight the "New" option and press the center button. Choose "Connects To Internet."Scroll down to the "Internet" heading and choose "Change." Key in the Access Point that you wrote down earlier. Scroll down and press "Done.Navigate back through the menu to the "GRPS" option. Press "New" again, and this time, choose "Connects To Wap." Choose the "MMS" option. Key in the MMS settings you wrote down earlier.Return to the main menu screen and then select "Messaging." Highlight "MMS" and press the right soft key to bring up a second menu. Choose "Settings," and then choose "MMSC Settings."Press "Edit" and enter in the "MMS" settings again. Scroll down to "WAP Gateway" and enter in the information you wrote down earlier.Power cycle the phone by turning it off and then back on to complete setting up the WAP settings.
  • Oct 01, 2010 | HTC Cell Phones
    Main Motor Error message on a Samsung color laser printer CLP510
    Hello Don,
    One other fix you can try is accessing the hidden maintenance mode. Try this;
    You can enter the menu in this way:
    Start up the machine with push in the buttons "online" and "cancel"
    --You will see the message "Download mode press online key"
    Press about 15 times the "menu" key
    --You will see the message "Uncheck consumable mode"
    Press about 15 times "menu" and 5 times "enter"
    --You will see "Press access key"
    Press a few enters
    Press 3 times "cancel"
    Go to the EDC mode
    -- you will see "press access key"
    Press "cancel"
    Go to maintenance and initialize the parts you like to reset.
    Dec 01, 2008 | Samsung CLP-510 Laser Printer
    Nokia 5185
    In order to change your voicemail message you need to call into your voicemail system. Voicemail is not actually in the phone but a service where your calls are forwarded to. Most voicemail systems will play the main menu if you press the * key. One of them should be about a greeting. Check with your carrier for specifics.
    Feb 03, 2008 | Nokia 5185i
    Panasonic phone KX-TGA109EX
    to access the answer machine press the top left hand button until a swirly thing flashes then press 5 to listen to your messages, then press the hash button to remove the message.
    To lock and unlock the keypab also press the hash key. It has a key symbol on it.
    Feb 02, 2008 | Lands Phones
    To record a new message on my Sharp UX 265
    press OGMn key
    select O x general outgoing message
    pick up handset and record your message (max 60 seconds) (best 30 seconds
    recommend pause 2 seconds before starting recording.
    press stop when finished.
    press OGM to listen to recorded announcement. redo as above if not happy w it.
    Cheers
    ojgv@comcast.net
    Nov 28, 2007 | Office Equipment & Supplies
    Cell Phones Logo
    19 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
