Question about Faberware 10-22 Cup Coffee Urn
Why is water leaking out of spigot lever of coffee urn?
It may not be screwed in correctly -- the spigot. mine seems to get out of wack after just being stored for a while
Posted on Oct 16, 2010
My bunn coffee maker leaks at the bottom. Can you tell me what to do
Okay no model given,
* Pour over brewers only leak if over filled (more than a pot). If it leaks just sitting there then there is a hole in the tank. Call for service or replace.
* Commercial machines like CW, CWTF, Single, Dual, Urns, are plumbed into a water line. Leaks may come from the water line, Tank, or urn.
* If the water leak is clear and not hot then it's the water inlet line.
* If it's hot then the heater is leaking,
* If it's coffee colored then it's the urn where the coffee is being brewed.
* In All cases call your vendor for service as this is a hazardous situation. Unplug or turn off the power to the unit. It should be on a large throw switch near any large brewer. Have maintenance turn off the breaker and leave of till the vendor can service.
Aloha, ukeboy57
Aug 09, 2017 | Bunn Coffee Makers & Espresso Machines
The spigot leaks. It seems the threads on the inner screw-on nut have stripped and we can't get a leak-free spigot. The urn is being used in our staff lunch room at Rain Forest International School in...
if you can get hold of some plumbers ptfe tape then that might fix the problem, dissasemble the spigot and wrap the tape round the stripped threads, then do up tight. a heavy duty filler such as chemical metal would do the trick too.
if you cant get hold of these bits then there is a temporaary fix that might work, dissasemble the spigot and coat the threads with loads of egg white, put it back together and heat it up until the egg cooks, with a bit of luck it will expand enough to seal the joint (this can work on leaking car radiators too).
good luck
Nov 25, 2010 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
Need to replace my spigot on my 30 cup revere ware coffee maker because it leaks. Where can I get one to "pop" into that hole so I can pour the coffee out of the pot into the cups.
I have a Westbend 24 cup coffee urn with a leaky faucet. I tried finding areplacement spigot for it but so far no luck. My spigot has a screw in the top that allow for disassembly. It looks to me that if I could get a replacement rubber O-ring I could fix it myself. Does anyone know where I could get this?
Thanks
Kelvin
kelvinlov@gmail.com
Sep 16, 2010 | West Bend (59055) Stainless steel 60-Cup...
Coffee does not flow through spigot
Keep running a bottle of vineagar through it. Good luck Ron
Apr 20, 2010 | Faberware 12-55 Cup Coffee Urn
Coffee leaks out onto counter after brewed. Is there a simple solution to fix this?
The bottom of the urn is sealed with a bright yellow rubbery gasket. As the button is pressed inward by the cup, a sliding lever lifts a valve in the urn. That gasket sometimes splits or wears, or sometimes a grain of coffee gets trapped between it and the valve seat. First try turning the empty urn (only the urn) upside down over your sink and pressing on the little lever under the bottom, while running a strong stream of water directly at the opening. You'll have to experiment to find how to press. That may clear the obstruction. If that doesn't work, replace the gasket. Instructions are in your owners manual.
Jul 30, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Faberware Coffee Urn 55 cup
I was able to buy a spigot for my Farberware Coffee Urn FSU236 from Mxim/Toastmaster in Macon, MO PHONE: 1-800-233-9054
Jul 25, 2008 | Faberware 12-55 Cup Coffee Urn
Leaking Around Spigot, Coffee Urn
I have a Farberware L1360 with the same problem . If there is water in the pot , in about an hour a nice little puddle forms . It is leaking right where the spigot attaches to the body of the pot. I can see a rubber washer squeezing out around this spot. Maybe It melted?
I think it needs some heat resistant washer to replace it. Farberware co. doesnt really exist anymore. you can barely get parts. If the spigot itself works, mine does. I can't see buying a new one if it just needs a washer. Does anyone know what type of washer would be a good replacement?
Jan 09, 2008 | Pasquini Livia 90 Espresso Machine
Faberware 10-22 Cup Coffee Urn Logo
146 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
