Question about Microsoft Xbox Console
New controller purchased flashes green contantly and no quadrant is assigned
A new controller I bought to add to the one from my game just flashes green and does not get assigned a quadrant. It is somenting i am doeing wrong. Just bought the game and am new to this.
    Problem Solver:
  • 3 Answers
Re: new controller purchased flashes green contantly and...
Post this under xbox 360, it's in original xbox right now.
Posted on Dec 05, 2007
0 characters
3 Points
Game loads okay but controller does not work. controller is brand new. lights work on controller but can not ply any games
If the controller is brand new, you need to Sync it with your XBox 360.
Turn on your 360 using the button on the console.
Turn on the controller by holding the X button in the middle.
With both on, click the SYNC button on the xbox 360.
Then click the SYNC button on the Controller.
The green ring around both should flash a few times, then the upper left quadrant should light up on both meaning it's Sync'd.
Mar 17, 2010 | Microsoft Xbox 360 Wireless Controller
I cant get the xbox to work from the controllers, when i press the "x" button on the controller it just keeps flashing and doesn't allow me to link up with the console
The "x" button is the xbox guide button that is in the center of your controller.
1. First, turn on your console by pressing the power button on the console itself.
2. Next, press the xbox guide button that's on your controller. (The button that lights up and flashes when you press it).
3. On the front of your console, just to the right of the memory card B slot & just below the right corner of the DVD tray, there is a small, round connect button.
4. With the both the console & the controller on,(lights flashing) press and release the connect button on the console first.
5. Then on the controller, press the connect button (green arrow, circled in red) that's between the Left Bumper button (LB) and the charging port (blue arrow).
6.The lights on the controller and on the console should continue to go in a circle and stop.
7. The upper left quadrant is controller # 1, the upper right quadrant is controller # 2, bottom left is # 3, and the bottom right is # 4.
8. Once the controller connects the the console,you're all set. Then the next time you go to turn it on, just press the xbox guide button on the controller and it will turn the power on to the console for you.
9. If you ever take your controller and use it on another 360 console, you have to go through the same connection steps as you just did. And then again, when you get back to your console
Hope this helps! Happy gaming!
Dec 17, 2009 | Microsoft Xbox 360 Console
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
Nov 23, 2009 | Microsoft Xbox 360 Console
What is RROD? I'm not knowledgeable about the X box but am comsiedring buying a used one for my grandson. Can you help?
RROD stand's for "Red Ring of Death." its a problem of epidemic proportions the xbox 360 has been facing since it first hit the market almost 4 years ago. The front of the Xbox has a reticule made up of 4 light-up quadrants. Typically these lights glow green when the console is activated & usually only indicate how many controllers are connected to the console. When these quadrants ever glow red, that means there's a problem with the hardware. the "RROD" consists of 3 of these quadrants being lit up. if this ever happens, the console will have a complete system failure & will almost definitely never work properly again unless repaired. if someone is selling you a console that he/she describes with "RROD" in it's description that means the console is currently suffering from that particular problem. Now, if the console is still under warranty (which has been extended to 3 years now) & hasn't been tampered with or previously refurbished, it can be sent in to Microsoft for repairs completely free of charge. I'm assuming your drawn to these "RROD" described consoles because they are significantly cheaper than the new or used ones you've seen am i right? it is most likely that these consoles no longer have their warranty & are being sold because either their owners have no means, cash or desire to fix them themselves or they're selling them for use as parts to more tech-savvy buyers. whatever the case may be, be careful in your purchase.
Oct 29, 2009 | Microsoft Xbox 360 Console
I have the lower right quadrant flashing red error e 73
This is a AV problem. Try changing the position of the HDTV/TV switch on your AV cable.
Aug 11, 2009 | Microsoft Xbox 360 Console
I keep getting three red rings in the part where it shows how may controllers are playing and i can't get any of my games to play or my controllers to work
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console.
You can try one or two things.
1. Turn on your xbox and check to see if the power supply light is green. If it is green there is a problem with the system. If it is red it means you should check your connections and restart the xbox.
2. These rings have a tendency of meaning that there is a problem with the system itself. Most companies sell extra insurance to cover this "ROL" Ring of life. You can contact Microsoft by calling them. The number is usually listed on the back of the video game booklets.
I wish you the best and I hope this resolved your problem
Happy Gaming
Oct 18, 2008 | Video Game Consoles
Setting up a 360 wireless controller
Turn Your Console and Controller On The Xbox® Guide button in the center of your controller puts the Xbox 360® experience at your fingertips. Press and hold the Xbox Guide button to turn your console on.
To turn on your console only, press the power button on your console. To turn on your controller only, press the Start button on your controller.
Once on, pressing the Xbox Guide button gives you immediate access to the Xbox Guide. To turn off your console, press and hold the Xbox Guide button for three seconds and then confirm your selection.
Turn Your Console and Controller Off To turn your console and controller off, press and hold the Xbox Guide button on your controller for three seconds. Then select whether you want to turn off just your controller or both your controller and your console. (Selecting the console will turn off both the console and all connected controllers.)
To turn off one controller when multiple wireless controllers are connected, press and hold for three seconds the Xbox Guide button of the controller you want to turn off, then select Turn Off Controller.
To turn off your console only, press the power button on your console
When you connect a controller to your console, it is assigned a specific quadrant, which glows green to indicate the controller's number and position. Each subsequent controller connected to the console (up to four) is assigned an additional quadrant.
If system problems should arise, the Ring of Light on the console will flash combinations of red.
I hope this solved your problem.
Happy Gaming!
Oct 17, 2008 | Microsoft Xbox 360 Wireless Controller
Cant connect a big ben interactive controller to a playstation 3
bigben controller and ps3
i had this problem with bigben mega pack bought with ps3 nov08
the problem is caused i find that the sony wireless controller supplied
has been already allocated as number 1 controller, this has to be changed while the bigben matches
the FIX:
boot the machine with sony controller and go into
settings\accessory settings\reassign controllers\ and re-assign the sony as number 3
(use left stick to move numbers up/down)
plug in the bigben receiver unit into a usb slot and then switch on the bigben
now the receiver light should now stop flashing and the bigben now has a single light agains number 1
go again into re-assign controllers and change the bigben to number 2
then re-assign the sony controller from number 3 to number 1
close down system
re-boot using the sony PS button (the bigben PS button does not boot PS3)
the sony should now be indicating that it is again number 1
the bigben receiver unit should have a steady red light but
the bigben will have all the lights flashing - click the PS button and they will stop
it now should only showing one light next to number 2, so is assigned as number 2 conroller
thats it
Note: I wanted to use 2 controllers for the game 'littlebigplanet'
Now if the two controllers are on, the game asks to assign a profile for the
other controller when it opens, so then you choose another user (that u have created)
Then another rag doll drops into the pod that is controlled only by the bigben (user2)
Aug 19, 2008 | Video Game Consoles
I have one flashing light on right quadrant.
Your LSU graphics sub-processing unit has failed. Trade it in to Gamestop for $20 and put it towards the purchase of a Wii or PS3.
Billy D
Apr 25, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
56 people viewed this question
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
