Question about Grilling
The grill will only start with a fire starter at the end of the b
When I ignite my Weber Silver grill, the fire catches at the end of a burner with fire starter NOT at the beginning. What can I do fix it? The igniter does work.
  • 10,865 Answers
At Weber, we believe everyday is a good day to grill, so we stand ready to answer your questions and impart advice from 7am to 11pm CDT/CST. Call us at 1-800-446-1071, and one of our grilling experts will be there to help you seven days a week.
Posted on Jul 16, 2009
I thoroughly cleaned my Weber Genesis Silver A and have a full tank of gas. It won't get hotter than 250-300 degrees. Flames are blue.
You might have air block. When turning off the grill, leave one burner on and shut the tank valve.
When grill cools, close the remaining valve. When restarting the grill, open the tank valve, then the start burner, then the igniter. When first burner is going, open remaining two valves to preheat the grill.
This has worked on two different grills.
Dec 30, 2010 | Weber Genesis Silver A Grill
The starter button does not seem to be igniting the propane
Its not, and this is common after about a handful of uses. The igniter is covered with sooot or grease or broken. They sell universal igniters at Sears for like 3 or 4 dollars. Your only other option is to strike long length matches and use those to light it. Be careful , always stand back when lighting grills or any kind off fire. hope this helps.
Jul 20, 2010 | Weber Genesis Silver B Grill
Webber grill won't ignite
Bad starter you can get one at Home Depot! If that does not work it is a bad electrode!
Jul 06, 2010 | Weber Genesis Silver A Grill
Replacing burners and ignition starter - Weber Genesis A grill
It's very simple buy the parts and follow the directions
Jun 21, 2010 | Weber Genesis Silver A Grill
My silver c igniter does not work..need to manually light..burners work..is new igniter worth pruchase? grill is almost 6 years old
yes replace it. you can call weber and they will send you one FREE just tell them whats wrong and the model number of the grill
Jul 18, 2009 | Weber Genesis Silver C Grill
Second burner will not ignite on Weber grill
Its probably an obstruction in the burner. Take both the burners off and clean them inside and out with a brass brush. You need to clean them both, since the second burner is dependent on the first working properly.
Step by step procedures are in your manual. Go to http://weber.com/help/manuals.aspx to download it.
Jun 03, 2009 | Weber 1851001 Gas Grill
Ignite prob
You've got two different things going on.  First - the type of igniter used on your model does wear.  I have had mine for over 10 years and have gone through 3 such igniters - and I grill nearly 3 times per week over the 25 week "grilling" season where I live. Spring for the $12 part and just replace it. The other issue sounds like a clogged cross-over system.  I would remove the burners, including the cross-over bar on the far left side that connects them.  Clean the exterior with a stiff steel/brass brush and the inside with a bottle brush.  Make sure all the holes are clear to allow gas to flow easily - use a wooden tooth-pick to do this to make sure you don't change the size of the holes! Put that baby back together and I think you'll find you'll be good as new!
These grills are great.  Now, if Weber could only fix the uneven heat problem between the left and right side I'd REALLY be happy!  (I wish they would even just admit there IS a problem!)
Good luck and happy grilling.
Mar 03, 2008 | Weber Genesis Silver B Grill
Grilling Logo
120 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
