Question about Crosley CR78CD-P CD Shelf System
Crosley Radio CR78CD
I have a Crosley Radio CR78CD and I can't get it out of stand by. I check the switch and the switch is good. If anybody else had this problem and got it solve send me an email at electroddx@yahoo.com I will glady appreciate it.
  • 3 more comments
  • mikeim Nov 18, 2007
    I have the same problem. I've tested the standby switch and it appears to be working fine. Are there any schematics available on-line? Any help would sure be apprectiated.
  • piewagon Jan 01, 2008
    I am an electronic engineer who previously did service work on radio,TV. My nephew has this CR78CD that he asked me to look at - gift from his mom so doesn't want to toss it. It has power and just comes up in STANDBY with no other function. Crosley will NOT supply any technical support to even give me a chance. I know I could fix it, if they would just sell me a minimum of tech help like a simple schematic. They won't so shame on them. Crosley was once a very good American company - now they sell foreign junk and won't even help customers to repair it or give them a chance at it. Don't buy products from this company.
  • Anonymous Feb 07, 2008
    I have this identical problem - locked in standby.
  • Anonymous Mar 29, 2008
    Same exact problem. I put in a request to Crosley support. Hopefully they will either know how to fix it or I can send it in for a replacement.
  • Finesse117 Feb 07, 2009
    I have the same problem - standby light comes on, but nothing else. Has anyone been able to fix this?
Crosley radio CR248 can not get anything to work display screen shows ON but nothing will work
Type " Crosley CR248 user manual " into search engine and it will show sites to get manual. Some radios have 2 fuses in them. I could be blown. If you attempt to check the fuses... UNPLUG RADIO !!!!!!
Nov 21, 2015 | Crosley Audio Players & Recorders
What would make a crosley 42" lcd tv not turn on
check the psu, if you can manually switch the power the power then its going to ease your work
May 27, 2014 | Crosley C42hdgb
Crosley cr78cd replacement needle
HI, stylus is Sharp STY146. Cheers John. Stylus City.
Apr 14, 2014 | Crosley Conductor CR73 Turntable
Looking for a remote for a Crosley cr78cd
Check the site linked below. It has setup code list to many popular brand remote controls. Refer them, and check which brand remote control have setup codes to Crosley. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 20, 2013 | Crosley New Original CR78CD Remote Control
Cr78cd
Contact the Crosley website they might have a free PDF of it.
Mar 31, 2013 | Crosley CR78CD-P CD Shelf System
Cannot get my new crosley out of standby mode. which button do you push as there is no standby button?
When it is off and plugged into the wall outlet the standby light will be on. The stadby light will go off when power button is pressed. If not there is poblem that needs service.
Dec 26, 2010 | Crosley CR78CD-P CD Shelf System
Turntable will not rotate when in "Phono" mode
I recently was given my Father's CR78CD and, assuming your unit is in working order, you turn on the turntable motor by lifting the tonearm off the post and moving it away from the turntable about one and a half to two inches. You should hear a soft click as the switch for the motor activates.
Jun 20, 2010 | Crosley CR78CD-P CD Shelf System
Need a belt
For belts, I recommend PRB belts - they are one of the only manufacturers left. However, they have been in the belt making business for a long time and their products are exactly what you need.
Here is a PRB distributor that can help you.
http://www.vintage-electronics.cc/vprbbelts.html
I hope that helps.
Oct 24, 2009 | Crosley CR78CD-P CD Shelf System
Crosley CR78CD-P CD Shelf System Logo
221 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
