Question about MSI Wind UmNotebook
Blue notebook UMPC (VIA C7-M 7" LCD)
My blue notebook UMPC (VIA C7-M with 7" TFT LCD) fail to boot, the last reported error said "the computer automatically shut down to prevent it from losing data and perform a stop error screen", The screen also stated that there is a software or hardware not properly installed. After that the monitor/LCD black-out. But why the laptop stop rebooting? Is it the power supply? Can you send me a schematic diagram? thanks...
Pxe e61 media test fail check cable
what error message are you receiving on the blue screen? if it resets to fast start typing f8 at boot and in the advanced menu, toggle down to do not restart on system failure. write down the hex code (0x00XXXXX) and report back. What version of windows are you running? have you tried to press f2 or f1 or whatever key it is to enter setup on your laptop @ boot and disable network boot?
Jun 11, 2012 | Toshiba Satellite M45-S2653 Notebook
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    Hp proliant server dl380 g3. gettting PXE-E61:Media test failure, check cable how to fix it..
    Your server tries to "boot" from several sources:
    * floppy-disk
    * CD/DVD
    * disk-drive
    * network (if you have a "boot-server" somewhere on your network)
    So, if your computer FAILS to boot from the first 3 devices, above, it will try the 4th, namely via your network-adapter.
    When your computer finds that its network-adapter is *NOT* connected via an Ethernet cable to a boot-server, it reports "check cable" and "test of the media has failed".
    So, why did your server *NOT* boot from the 3rd device, namely your disk-drive? Solve that problem, and the 4th device (the "network-boot") will not be tried, and the error-messages will not appear.
    Aug 27, 2010 | Computers & Internet
    There is horizontal line come in TFT in last 2 yr i ask the dealer he told that its bcoz some resister short now after another line come in my TFT whats the problem? and notice that this problem come after...
    You may have failing TFT (Thin Film Transistor, each pixel on the screen is driven by one transistor, so there are 100 of thousands on the LCD panel
    ) or bad connection or failing T-CON board.
    See pictures here:
    http://s807.photobucket.com/home/budm/allalbums
    http://en.wikipedia.org/wiki/Capacitor_plague
    It will usually get worst with more lines as time goes by. New panel will be needed.
    Jun 15, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
    I get a weird message when I try to boot up my computer. it is
    Sounds like a failed windows update crashed the operating system. If Vista, boot to the Vista DVD, select the option to repair your computer and see if that will resolve, repeat running the repair process until it reports no errors.
    If windows XP, boot to XP CD, press R at 1st prompt, run CHKDSK /R and see if that fixes the boot process.
    If those fail, then you might have some luck with a repair of your Windows Installation from the Windows CD
    Jan 11, 2010 | Dell Inspiron 1525 Notebook
    Monitor boots ok, then "Analog" appears/monitor shuts off
    Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
    Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
    Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
    Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
    your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
    them from Dell or even using somebody elses (match version with sticker on your laptop).
    Check the hdd connection underneath laptop - make sure cable is not loose, etc.
    Probably safe to say your data is gone unless you're willing to spend $$.
    Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
    ISH819 LCD MONITER WITH TFT?
    This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
    http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
    Under the User Manual heading, you will see ->
    2009-04-08 12:20:36
    To the right of that is -> cache <- in blue. Click on -> cache
    The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
    [18.5" (47.0cm) TFT Color LCD Monitor]
    May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
    ERROR MESSAGE READS...
    There seems to be some corruption on the hard drive. You need to boot up the laptop from the Windows installation cd. Once "Setup" has started, you need to look for the option "Recovery Console". Once loaded you may get asked which installation you want to log onto. Type in 1 and press Enter. Then type the following: CHKDSK /P and press Enter. This will run a checkdisk and more than likely report that it has fixed some errors on the drive. Now type EXIT and press enter. The system should now reboot, remember to remove the Windows installation cd. If this fails, you may have to take the laptop to an authorised dealer.
    Aug 30, 2007 | IBM ThinkPad R40 2722 Notebook
    MSI Wind UmNotebook Logo
    215 people viewed this question
    Top MSI Computers & Internet Experts
    David
    David
    Matthew Spark
    Matthew Spark
    Terry Hair
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
