Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacesaver microwave arching hub
Turntable motor and heating unit work. The hub that the glass tray sits on archs white electricity across the hub. Appears to be burning a line across the composite material that the hub is made of.
I FEEL THE COMPOSITE MATERIAL HAS SOMEHOW FAILED AND HOPE THAT REPLACING IT MIGHT SOVE THE PROBLEM. I don't want to spend much money on repair due to age and value of the unit.
The GE hotline  was absolutely worthless. They were unwilling to provide any guidance.(This is my last GE applinance.) WANTED ME TO CALL A TECH TO THE HOUSE. This would probably not be cost effective.
Has anyone encountered such a problem and what was the fix? Sorry about caps. I'm a terrible typist.
Falling Down
  • 67 Answers
SOURCE: Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Posted on Nov 30, 2007
  • 43 Answers
SOURCE: GE Spacesaver over the range microwave oven
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Posted on Jan 25, 2008
  • 43 Answers
SOURCE: burning odor, no heat
A burning smell along with a different sound (growl) USUALLY indicates a breakdown in the High Voltage Side. This is not a direct short (short circuit) or the line fuse would have blown shutting everything down. The High Voltage Side is made up of-- The Secondary ,or High Voltage Side of The High Voltage Transformer, A High Voltage Diode, A High Voltage Capacitor, and The Magnetron. If The High Voltage Transformer is the problem it will smell like a florescent light ballast burning, and will smell each time you turn on the MW. A HV Diode burns and opens, thus no more smell. A HV Capacitor usually does not burn nor does the Magnetron. There is no Cheap-Fix unless you can see that the HV Diode is burned into and you can get to it to replace. CAUTION: Always unplug from power before attempting to repair. NOTE: If you replace a Diode make sure it goes back in the same direction it came out. Yes there is a front and back.
Posted on Jan 26, 2008
SOURCE: Ge jvm1650wb005
weve had our fixed before and it's the heating element $75-$100 to fix.
Posted on Sep 01, 2008
  • 7 Answers
SOURCE: GE Spacesaver JVM 1651 Not heating, making burning smell
Fisrt, check to be sure your missing cat it not inside the unit. IF the interior is dirty (splatters, grease, etc.) , it may inhibit the unit from working properly.
Posted on Nov 22, 2008
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
Dec 15, 2015 | Microwave Ovens
I'm experiencing occasional arching from the center of the oven i.e. out of the spindle that rotates the metal rack and glass turntable. I cleaned thoroughly and it seems to have minimized the proble
Its unlikely to be associated with the tuntable motor. Units are tuned to prevent arching. Therefore it appears something may have changed inside the unit. Be sure there are no loose items or bits of foil or other mateallic items inside. Also check metal turntable.
Dec 31, 2011 | GE Advantium 120 Convection/Microwave Oven
Electrical arching between top metal plate and shell?
i would imagine its a shield but iam not completely sure without a good look
Nov 20, 2011 | GE XL1800 1100 Watts Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver microwave table wont turn
either your turntable motor part# WB26X10037 G.E. is bad or the motors capacitor part# AP2026076 is defective they are both the same price
Oct 08, 2009 | GE JVM1440 Microwave Oven
Turntable sometimes works, mostly doesn't
It sounds like you have a jamming turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 28, 2009 | Microwave Ovens
My Advantium was arching at the turntable. Replaced the turntable roller assembely (that hold the metal or glass plate) and the arching went away.
Nov 16, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
59 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
