Question about Philips 42PF7320A 42 in. Plasma HDTV
My phillips 42 in. goes directly to the menu screen.
When I turn it on. I exit the menu and within a second or two it switches back to the Menu screen. If I try to adjust any thing using the menu, it reverts to the main menu.....
  • 1 more comment
  • glpike1 Jul 19, 2009
    I've downloaded the software update, and put it on a memory stick. When I insert the stick and try to install the software, following the direction, the tv doesn't recognize that there is any software to be installed... I've tried it several times
    PS> I've tried 2 different memory sticks which have worked with other software.
  • glpike1 Jul 20, 2009
    I did unzip the file. twice. I tried downloading and unzipping two different times, same result. I've about given up.
    President:
  • 1,077 Answers
It's a common software problem with the Philips TVs. You'll have to download the latest software upgrade to fix the problem. Go to Philips.com/support to find the software for your TV. You'll need a USB memory stick to do the procedure followed on the web site.
Posted on Jul 16, 2009
  • Devon Sacco
    Devon Sacco Jul 19, 2009
    It's possible that the file needs to be "unzipped" before downloading on the memory stick.
    Most times when you download a file off the internet, the file is "zipped" ( compressed file ).
    Try downloading to the desktop, then unzipped the file, then download the unzipped file to the memory stick. Just make sure there is only the one unzipped file on the memory stick and nothing else. It should work after that.
  • Devon Sacco
    Devon Sacco Jul 20, 2009
    Sorry I could be a bigger help.
    It's possible that the software provided was listed wrong on the web site and wasn't compatible with your TV. Philips should have a compatible software for your TV.
    I would call up the support hotline listed on the Philips web site and see if they can find the correct one for you.
Screen blanks after 30 to 60 seconds
change 22mf-200v near fly back .
Apr 10, 2010 | Sharp 25K-M100 25" TV
Sound it on and can change channels, but no picture. The screen is showing the set-up mode. I have called the cable company thinking it was the box, removed the batteries from the remotes, re-booted...
try reset to defaults:
  1. Press the 'MENU' button.
  2. Press the cursor down to select SETTINGS.
  3. Press cursor right twice.
  4. Press the cursor down to select RESET AV SETTINGS.
  5. Press cursor right on START NOW. Press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Feb 20, 2010 | Televison & Video
Philips Tv always returns to menu screen
ssb board failing need to be replaced encompass.com
Sep 17, 2009 | Insignia 42" LCD Flat-Panel HDTV
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Phillips 42" flat screen defaulting back to set up menu
I am having the same problem. I thought it was the remote control so I took the batteries out. Same issue. Then I disconnected my wireless Internet router.. same issue... I guess it is a hardware problem
Jun 21, 2009 | Insignia 42" LCD Flat-Panel HDTV
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Menu
I download new software from internet and insert to TV and it works.
Apr 27, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
On screen menus in every language barring english
Press the SUB-POWER button, INPUT SELECT button and UP Arrow button at the same time, and hold for more than 5 seconds.
Jan 15, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Contrast Menu appears after switch On
Contrast Menu appears after switch...
Jan 02, 2008 | Philips Standard 105S Monitor
Unable to exit TV's menu
Try to replace the remote sensor board inside the bottom of your tv. If that won't work, you need to replace the Small Signal Board (SSD Assy) of your tv.
Nov 24, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 42PF7320A 42 in. Plasma HDTV Logo
266 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
