Question about Navman Tracker 5600 GPS Receiver
Display can hardly be seen even with backlight set to max and colour on sunlight
I have the same problem. The backlight in mine has blown. Its a small fluro type globe I we cant buy one anywhere......Any ideas other than nav,an ?
Posted on Aug 02, 2009
  • g_boddenberg Sep 03, 2011
    My Navman had a similar problem however it turned out NOT to be the tube but the electronics.
    Since no parts are anylonger available I tried the following with success. First I tested the tubes a few seconds in a microwave oven (YES, a microwave!) and the tubes lit up. A Marine repair shop let me know that the HT transformer was blown, however I tested this transformer myself and turned out to be OK. I purchased a small CCFL Inverter for DC 12V at Euro 4.50 and installed the assy in the housing of my Tracker 5607. Perfect backlight again! Day/night switch works OK, only day backlight cannot be adjusted anymore and remains on full power. I aleways had the plotter on full power anyhow.
  • kjetil bjornstad Mar 25, 2018
    hello! Would you provide a link to ebay as to what inverter you bought? I have the same issue!
Why do red objects, but not the white and black parts, sometimes cannot be seen on the monitor?
Red is the universal warning colour, so chosen because it is visible in most lighting conditions.
Dec 14, 2016 | Cameras
How can I see display better in sunlight?
Viewing screens that make use of "back lights" (LEDs, fluorescent, etc) to see / read the display in direct sunlight is often very difficult. Increasing the back lighting level is one method - but even when at 100% brightness, it is hard to overcome the sun. Shielding the screen from sunlight with your hand, body, etc., is often the only way that works effectively.
Apr 10, 2015 | Cell Phones
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen.
As there are high voltages on inverters, this is really a job for a repair shop.
Dec 11, 2013 | Dell E193FPC 19" TFT LCD Flat Panel...
The colour of my hp4520s has changed....the predominant colour now is pink, however its hard to distinguish the colours....and some portions blink
Try
Start > Control Panel > Display > Calibrate Color > How do I calibrate My Display >
Just step through this carefully and hopefully your colors will be corrected.
I have a 4520s but never have done this.
Nov 15, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
My screen of my 'coolpix s225' has gone completley blank. it is a greyish colour but occasionly a small strip of screen will work. its nothing to do with the lens becasuse i cant even view pictures
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the phone aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Aug 03, 2011 | Cameras
Screen is black, backlighting gone, but camera still works. Is there a solution for fixing?
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
Jul 26, 2011 | Panasonic Lumix DMC-FX9 Digital Camera
Front display poising backlight and goes dim.
I believe this is most likely due to incorrect voltages at the display. If you have a meter and are familiar with working on electronics, check the voltage at pin 3 of cn501. It should be -28.5. If the voltage is very low, try changing C123 and C124 in the power supply. If the voltage is ok, check R925 and R932, these are both 10 ohm 1/8th watt.
Dec 13, 2017 | Aiwa AV-D97 Receiver
Faulty Display
It could be a bad connection in the wiring between your display and the keypad. You should get it checked out at a cell phone store especially if it's still covered under warranty.
Jul 04, 2008 | Motorola Mobility W375 Cellular Phone
Mitsubishi xc-3716c monitor
ttl is in short from Transistor-Transistor Logic.
Apr 18, 2008 | Computers & Internet
Display
A really dim display like you're describing is most likely a backlight problem.  If your inverter went bad you wouldn't have any display at all.  you need to get your backlight changed.
Oct 10, 2007 | Acer Aspire 5002WLMi Notebook
Navman Tracker 5600 GPS Receiver Logo
315 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
