Question about Maytag MEC5430BDS Electric Cooktop
The heat indicator light does not turn off even when burner is cold
  • 999 Answers
It is either the control for that burner or the sensor on the burner. have to check with a meter to verify which one it is.
Eric
Posted on Jul 16, 2009
Cook top indicator lights stay on long after it has cooled off. The largest cook circle sometimes doesn't reduce heat when the dial is changed
Cook top indicator light will stay on as long as the stove is hot I think. Also, the burners don't heat real steady? or evenly or true to their settings even, quite often. they also take a really long time to cool down as well as to adjust temperatures, so it may just be that it is taking an awfully long time for it to cool down in order to adjust.
Apr 04, 2015 | Cooktops
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
Indicator light on my maytag electric smoothtop range will not shut off even though the indicators are off?
One of the high heat sensors has failed on one of the burners under the glass. Disconnect one sensor at a time to find out which one, then replace that burner assembly.
Feb 19, 2011 | Maytag MEC5430BDS Electric Cooktop
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Jan 18, 2011 | Maytag Cooktops
On indicator light on my Maytag touch control 500 electric smoothtop range will not turn off, even though all burners are turned off. I also shut the power off but the light still stays on
I can't help you with this if the light will not go off on one burner then replace that switch . but if you turn the power off and the light still is on. the unit is getting power from another unknowen source . mm
Jul 08, 2010 | Maytag MEC5430BDS Electric Cooktop
Burner light does not go off on Amana AKT3040
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Apr 05, 2008 | Amana AKT3040 Electric Cooktop
On light flashes
i would replace the custom control kit. elemnt usually fine that contorol kit is a new circuit board that only controls that one burner
Mar 09, 2008 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Maytag MEC5430BDS Electric Cooktop Logo
275 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
