Question about Kenmore 75085 Air Conditioner
Air conditioner trips off when filter on front, and even when running is not cooling very well. Any advice or insights would be appreciated!
  • 146 Answers
Well check to see that front coils and back are clean.
Posted on Jul 16, 2009
My portable. Air conditioner. Isn't cooling
Could be a number of things, Is the compressor running? If so, are the filters clean? ( Both the outlet and the inlet filters.) One at the front where the air comes out and one at the back where the air goes in.
Sep 07, 2013 | Portable Air Conditioners Portable Cooling...
Hi, I have a Friedrich air conditioner. Old one I am pretty sure. Maybe 9 years. Model is SL28J30A-D. I have a feeling my filter is not working properly or I don't even have the right one in. Currently I...
The evaporator coil (cold coil) would freeze up if the air entering is restricted. It could shut down because the rear coil (condenser coil) is dirty or obstructed. Sometimes there's debris or even bird's nest blocking the condenser air outlet, this causes heat and high head pressure.
Aug 27, 2013 | Friedrich Heating & Cooling
My Edgestar AP410HS triggers the circuit breaker in the circuit box outside the house after it's been running a few minutes in air conditioner mode. This is new, it hasn't happened until a few days...
Breaker tripping likely from a loose or bad connection. Wire is getting over heated from not being tight. CAREFULLY INSPECT ALL CONNECTIONS. Including inside the disconnect box outside. Possibly even a bad breaker. HIGH VOLTAGE IS DANGEROUS , if even the slightest bit nervous, call a professional! Good Luck
Mar 29, 2017 | EdgeStar AP410HS Portable Air Conditioner
Filter dirty and blowing warm air
If your filter is dirty,the fan inside the house cannot push the cold air thru the evaporator, cool air cannot circulate, this will cause the compressor outside to over heat and even damage it and possible trip some fuses or circuit breakers, with these hotter days you want to change out your filters more often, changing out your filters more often will keep the evaporator cleaner and allow the cool air to flow, easier.good luck!
Aug 08, 2011 | Goodman CLJ36AR42 Air Conditioner
Hi. My 2 year old Friedrich CP10E10 window unit is not cooling the room like it should/like it has. I followed obvious troubleshooting steps per the operation guide, including thoroughly cleaning filter....
Check the OUTDOOR coil... it sounds like it is clogged up and the system is cutting out on high pressure...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Friedrich CP10E10 Thru-Wall/Window Air...
Upon removing the front cover of my aunt's very
I would try to clean the coils with a paint brush, then i would go to freds walmrt kmart or any other store that sells 30 day filters and buy some. Take it to my aunts house, cut the filter to fit in front of the coils and behind the cover.
Jul 21, 2010 | Airtemp B4X05F2A Air Conditioner
Units runs but cool air will stop even thou blower continues to run after several minutes cool air starts again
Check the theremostat probe to see if it may be too close to the evaporator fins behind filter if touching fins it will feel evaporator being cold before room air and send model number too, Sea Breeze
May 21, 2010 | LG Electronic Window Air Conditioner
Fan running but no heat
It could be the circuit board, relay, heat strip coil or limit. If you have the fan switch at the t-stat in auto and the fan is running constantly it's probably a high temp limit that tripped. Was your filter clean or dirty? If you had a dirty filter and/or A/C coil it will restrict air flow and cause the furnace to overheat.
Jan 18, 2009 | Carrier 38CKC042 Air Conditioner
LG LWHD1800R air conditioner problem
It sounds to me like the compressor is overheating and tripping on internal or external overloads. After the unit cools down again it will try to run for a little while. Then this cycle would start over. I would check the condenser coil for dirt and filth. This portion of the unit may be on the out and backside of the unit. You should at least be able to see light through the coil.
I believe the thermistor that you removed temporarily is used for a freeze situation. I do not believe that it is your problem. Good luck:)
May 17, 2008 | LG LWHD1800R Wall/Window Air Conditioner
ROOF AC UNIT ISSUES
Ice on the coil is caused by 3 things; 1, low freon charge. 2, inadequate air flow across the coil, this can be a filter or dirty coil (I think you addressed these) or the fan isn't blowing enough air over the coil. 3, the unit is running continuously. A heat pump has another cause, that is something defective in the defrost system, like the sensor, reversing valve, control board or relay. If the breaker is tripping its because the compressor is over amping. There can be an obstruction blocking the fan or something like #2. Or the compressor is going out. If the breaker doesn't trip on other settings, like cool, but trips on heat, then I would look at the airflow.
Mar 14, 2008 | Dometic Rooftop RV Air Conditioner
Kenmore 75085 Air Conditioner Logo
63 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
