Question about M-Audio MicroTrack 24/96
Can't get flash card out of microtrack unit--switch on side of unit is supposed to flip out on hinge, but won't do that--
  • 322 Answers
Try pushing it and release quickly, most of this equipments work like that.
Posted on Jul 16, 2009
One side of oven door hinge won't fit back in when putting door back on after cleaning
when you insert the hinges back into place flip the small lock tab at the hinge pin the locks the hinge for removal
Oct 19, 2017 | Indesit KP9508EXG Dual Fuel (Electric and...
Won't record
I suggest that you to select Reset to Factory Defaults in the System menu to soft reset reset the unit or by pressing Delete and the power button and holding them down to hard reset. Good luck!
Dec 14, 2007 | M-Audio MicroTrack 24/96
Put card in camera and it reads "Card Locked!" How do I unlock it?
There is a little switch on th side ( very small) ..... Flip that :) hope I helped!
Mar 24, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
M Audio Microtrack 24/96 MP3 recorder battery short life. How to change battery? No screws in body.
I had this issue and had to return the unit to the manufacturer for repair.
Nov 22, 2010 | M-Audio MicroTrack 24/96
How do i change my freezer door to open the other way
you will need to take the upper hinge off first, then the door will lift off the bottom hinge. Then take off bot hinge and move both hinges to the holes on the other side. As far as the handel goes, you may need to flip it over or switch the handel to the other side
Oct 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Disk is write protected
did you flip the little switch on the side of the memory card?
Jun 16, 2009 | Kingston 4GB Secure Digital High Capacity...
Microtrack screen is on and frozen
I was able to clear the same issue by removing the CF memory and erasing it using a USB card reader connected to my PC. I erased all the files and reinstalled the card in the Microtrack. Works fine now, must have been a corrupted file even though it only contained two mp3s I had recorded earlier.
Dec 19, 2008 | M-Audio MicroTrack 24/96
It wont work!!
Flip the switch and it will be fine.
Jul 14, 2008 | Nikai DV7000 Camcorder
New camera
Hi, I had the same problem but all you nee dto do is take out the card and flip the tiny switch on the side of it
Jan 18, 2008 | Samsung Digimax S730 Digital Camera
This is suppose to hold hours of recording time and mine only holds a few minutes. How do I increase the time?????
Two things to try: make sure you have a big enough memory card for the intended format and recording time. I suspect you are trying to use the 16MB Compact Flash card that came in the box. A 1GB card will record much longer than the battery life in the Microtrack 24/96, even when recording 24-bit stereo in WAV format. If you have a smaller card, and want long recording times, use an MP3 format. Using the MP3 encoder, monophonic recording, 128K bits/sec, 44.1K samples/sec, you should be able to record over 16hrs of audio on a 1GB memory card. Same card, WAV encoder, 44.1K samples/sec, stereo, 24-bit audio will produce only a little over one hour of recording time. With the 64MB card that came with the recorder, the most you can record using WAV encoding, 24-bit audio, 44.1K samples/sec, is a little less than 4 minutes. With 16-bit audio about 6 min, and with mono and 16-bit audio about 12 min. With WAV, 24-bit audio, mono recording yields 7:52.
Nov 07, 2007 | M-Audio MicroTrack 24/96
M-Audio MicroTrack 24/96 Logo
66 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
