Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
The auto oiler for the chain is not working, what should i look for
  • ProHydroRace May 11, 2010
    Have you fill the oil revesivor?
    Have you put oil into the saw?
  • 76 Answers
Hi
try this steps and proceed from one to the next :
1. make sure you filled oil
2. clean the chain oil container with gasoline
3. try thinner oil
Posted on Jul 17, 2009
BUY ANOTHER CHAINSAW, i GOT ONE OF THESE BUT THE OILER GETS CLOGED WITH SAWDUST
Posted on Jul 27, 2009
2 Suggested Answers
  • 2239 Answers
SOURCE: auto chain oiler not working
To remove the pump, start by removing the two 19mm bar nuts, remove the side cover, bar and chain, remove the c clip on the end of the crank, now remove the clutch drum, you now need a special tool to remove the clutch, part no, 530031112,the clutch is just spun onto the crank, left hand thread, the tool fits into the two cut a ways in the clutch centre and allows you to jar it off against compression, once removed there are just two screws retaining the pump assembly, check both gears for wear, you can now also pry out the oil pick up tube.
Posted on Feb 27, 2011
Why wont the auto chin oiler work
why is your chin squeaking??
Sep 08, 2017 | Garden
I have a McCulloch CS38EM Why is the auto oiler not producing oil to chain. The port seems to be clear.
There is a spiral ring that drives the oiler on the crankshaft. Sometimes that slips and no longer turns the oiler. You can move it back and put a few drops of thread locker on the shaft before you place the spiral in place.
Oct 28, 2016 | McCulloch Garden
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
https://www.youtube.com/watch?v=PnNTJ3xI_wo
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
HOW TO REPAIR CHAINSAW OILER - YouTube
? 6:38
https://www.youtube.com/watch?v=kmUkieIP-vw
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
Stihl chainsaw (Farm Boss) - chain oiler has stopped working, how do I check the fault ?
Hi John...
You will need to remove the bar and chain...behind the bar is the auto oiler it works on the shaft of the chainsaw, you will have to remove it and clean all the outlets for the oil to the chain.
Please take time to rate me
Bud
Mar 10, 2013 | Garden
I have a1640 partner and the oiler pump does not pump out oil when in use. I cleaned the saw and I have lost the cap which fits on the end of the plunger of the oil pump
Hi allanpriest...
Forget the auto oiler...use a handheld oil gun to lube the chain on your saw...just lube the chain approx. every 2 - 4 minutes of use
Sep 15, 2011 | Electrolux Garden
I need to know the oil gas ratio, and about chain
Hi ccollins529...
Normally a 50 to 1 mixture is fine...1 pint 2 cycle oil to 6 gallons of gasoline.
Use "bar and chain" oil on the bar, this is an oil blended for the chain and bar.
If yours has an auto oiler you will put the oil in the bar/chain oil container.
If you do not have an auto oiler,use a hand oiler to lube the chain when needed.
Aug 28, 2011 | Garden
Your response about the electric chain saw that must be oiled manually was about a self-oiling chain saw so it did not answer my question. How to oil the saw? Use an oil can to spread the oild across the...
Your chain saw is a manually oiled model which means YOU have to pump it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent you the link to the owner manual and gave you a diagram. Click here
Jul 15, 2011 | Garden
Auto oiler not working
Remove the bar cover. Remove the chain and bar. Behind the bar you will see a set of 4 or 5 small square openings. This is the auto oiler. Make sure they are not obstructed with gunk. There is also an adjustment to increase the oil flow to the bar. It is a small screw and will be marked with a + on one side and a - on the other. You can adjust it to run from 5 (minimum) to 15ml (maximum) per minute. Never use old motor oil or 2 cycle oil in yo
May 22, 2010 | Husqvarna Chain Saw 20" Bar
Chain binds saw dies saw runs fine with out bar chain on clutch bearing? help poluan 3416 16 inch 34cc
Is your chain oiler working? If you're using saw a lot and the oiler isn't working properly the chain will get hot and bind up especially if the chain is too tight. Tighten the chain so that you can squeeze it in the center of the bar, with your second and third finger on the sides of your fingers (not a very strong grip) and you should be able to almost pull the chain out of the bar guide but not quite. Clean the oiler hole in your bar where the chain oiler injects oil into the bar. You can also run your saw without a bar and chain and see if the oiler is pushing oil out of the injector.
Dec 04, 2009 | Tools & Hardware - Others
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
537 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
