Question about Toro Lawn Mower With Toro Power Tools
What part of the underside of the mower do I attach the cable?
  • 127 Answers
Which cable ?
Posted on Jul 26, 2009
After starting my lawn mower, it runs for a short time, vibrating and then stalls (stops).
Hi Abraham:
The vibrating could be coming from the blade.
Check:
- the centre bolt to make sure that it is securely attached,
- that the underside of the mower deck is not obstructed with grass
- that the blade is not bent.
If it will not start at all now you may have a sheared key on the flywheel.
May 13, 2015 | Garden
How does the belt go on a Craftsman FS5500
Step 1
Consult your owner's manual to get the proper part number for the drive belt needed for your particular lawn mower model and purchase it.
Step 2
Turn your lawn mower on its side or put your riding mower up on blocks so you can get to the underside of your mower's deck.
Step 3
Clean the underside of your deck. This can most easily be accomplished by carefully scraping the underside of the deck with a long handled flat blade screwdriver. Remove any pieces of drive belt that are still attached to the pulleys that are visible.
Step 4
Locate the tensioner. This is a pulley that can move when it is loosened. Use your ratchet to loosen the bolt holding the tensioner in place. Allow the tensioner to move closer to the other pulleys.
Step 5
Check your owner's manual for the proper way to position your drive belt over the pulleys. On most models the drive belt simply goes around the drive pulley, the tensioner and the pulley connected to the blades, but some models are slightly different.
Step 6
Pull the tensioner tight until there is less than 1/2 inch of play in the drive belt when you push on it between pulleys. Tighten the bolt holding the tensioner in place once the belt is as tight as the owner's manual suggests.
Jun 03, 2011 | Craftsman Garden
Where do i connect wires on new Intek briggs & stratton motor going into cox compact tractor Model09M7. Red, white, grey & black wires from motor.
i have similar problem robjanottle. the red connects to the power cable in the equipment harness and the white connects to the light switch.this is from B & S website where u can get wiring diagram for dual circuit alternator. ******** if i know where the grey and black wires go. the grey is attached to underside of fuel bowl but don't know where it ends up and maybe black is earth? i am going to local mower dealers to have a pretend look to buy mower but will only be interested to find where this friggin' grey wire goes to. good luck mate
Apr 24, 2011 | GPS
How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
Oct 15, 2010 | Toro Lawn Mower With Toro Power Tools
Throttle cable is loose from engine; where does it go?
Sears has thousands of illustrated parts breakdowns on their Parts Direct website that can be very helpful in solving this kind of problem. Along with their house-brands, they also have most other major brands available too.
Give it a try:
Sears Parts Direct
Jul 18, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
You first need to locate the model number on the mower, not the Briggs engine. Then go to searspartsdirect.com and enter your model number on the right side of the web page. This will take you to a list of parts for your mower. Your model number should be located on the deck of the mower (you didn't say if it was a rider or a push). Rider model numbers are located on the rear of the body behind, on or under the seat. Push model numbers are found on the back of the deck between where the handles attach to the frame.
May 25, 2009 | Craftsman Garden
The cable traction cable is broken on my toro personal pase lawn mower. part number 105-1844 how do i change it
I changed the cable on my toro mower but i cant make it go unless i pull back on the handle .i cant find a picture to see what i am doing wrongcan you help. Thanks
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
I have a cub cadet lt 1050 mower and I need to replace the drive belt (hydrostat belt). How do I do it?
I just replaced mine today and let me tell you it was a pain in the ****, Had to remove the deck, steering attachment on the underside,and the electric PTO. Took about two hours.
Apr 27, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
60 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
