Question about Yamaha Electrical Supplies
Trying to find carburator parts for a yamaha ef1000 generator and not having any luck online -- any suggestions? it is 1999 model -- i need a needle and seat and bowl gasket
SOURCE: Yamaha ef1000 will only idle and produce 12 vac
Hi, I have the same generator and I pull the load and it is fine. The engine RPM is controlled by the
governor. The voltage will not come up until the RPM is at full. First see what the RPM problem is and then check the voltage. Open the cover and look to see if the carb linkage is hooked up , if it is you mite have carb problem and address that first. Hope that helps.
Posted on Dec 19, 2008
rwvanlue
  • 486 Answers
SOURCE: Yamaha ef2400is generator needs some choke to run
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Dec 04, 2009
Last_Lion
  • 4 Answers
SOURCE: Yamaha EF1000 Will only idle and produce 12VAC
My guess would be that some failsafe is in action here. It is possible that either a fuse OR the breaker is bad, or is not resetting in the case of the breaker button. Yamaha likes to idiot proof these things. Some of them disable the sparkplug if the oil gets low. Forget about just a warning light.
Posted on Dec 06, 2009
  • 760 Answers
SOURCE: What steps do I take to get a Yamaha EF1000 gas
You can disconnect the fuel line from the carb and drain the gas. It would be even better to then remove the fuel tank. If this is the generator with the large plastic tank, quite often the rubber gromet in the bottom of the tank with shout off vavle in it will deteriorate into a black gooey mess, and leak. If so that will have to be replaced. Clean inside of tank with fresh gasoline. Remove bowl from carburator and clean throughly. If you know how to work on engines, remove the carburator and clean throughly, notice how all springs and linkage were connected before removeal. Be sure all passage ways in carb are clean. Always use sta-bill in your gas.
Posted on Jul 23, 2010
SOURCE: oil change
Tip it over sideways - no drain hole exists, just the inlet.
Posted on Dec 24, 2010
EF1000. Where can I get a circuit diagram?
they are avaible on the internet , Babbitts Yamaha Parts house has all parts online
Sep 22, 2015 | Yamaha Electrical Supplies
Does the yamaha EF1000is inverter generator 1kva
it seems to be the standard that the rating or model ??1000 or ??1500 or ??2500 or ??5000 or??5500 or ??6500 is the kv rating of the gen-set regardless of straight or inverter
so if yours is EF1000 it will be 1000 watts or 1 kv
remember that most electric drills are 1000 watt units so a unit this small is mostly good for lights, charging batteries, small compressors for tyres
Jul 04, 2015 | Yamaha Electrical Supplies
I have a 1985 virago 700 gas comes out exhaust i rebuilt carbs new needle and seat new intake rubbers still having same problem
Hi, Anonymous gasoline in the exhaust not good for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ViragoTechForum com
Gas coming out of exhaust help
Yamaha XV535 Owners Workshop Manual
OEM parts for Yamaha
YAMAHA XV535 Owner Manual
Jun 25, 2012 | Yamaha Motorcycles
Yamaha ef1000 will start then push choke in and generator stops
clean tank fuel lines air filter and completely clean all carb parts and jets just did mine runs mint now did the same thing i also put in a new spark plug changed the oil a good once over goes a long way just take your time use a good carb cleaner like crc or gumout and check the jets they have small holes on the sides that can clog up hope this helps
May 07, 2012 | Yamaha 1,000 Watt Portable Generator...
Generator EF1000 manual
A consumer guide to Yahama's Premium EF1000 with specs, pictures, reviews, and manuals to download. www.poweredgenerators.com www.poweredgenerators.com/yamaha/premium-ef1000.html
hope this will help you
Jan 31, 2012 | Electrical Supplies
What steps do I take to get a Yamaha EF1000 gas powered electric generator going again after it has been sitting around for years with gas in the tank? How do I drain the gas from the tank and carburater?...
Jul 23, 2010 | Yamaha Electrical Supplies
Oil change
Apr 01, 2009 | Yamaha Electrical Supplies
Dec 17, 2008 | Yamaha 2500 Watt Industrial Inverter...
Electrical Supplies Logo
106 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
