Question about Dishwashers
No power to unit, dishwasher model DU960PWKB1. Unit was running, then abrubtly stopped, leaving water in the tub, and no power to drain or run unit. All breakers good, no other signs of problem. Help!
  • 6,784 Answers
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jul 16, 2009
Diplomat dishwasher ADP 8322 - previously not draining but neither was the sink and I've unblocked that which is now working fine. When I put it on it bleeps continuously after about 5 minutes
Hello Simon,
No water in the tub would indicate the drain is clear (unless it never filled at all...have you confirmed? Do you hear water leaving the unit?).
Those bleeps and flashing lights are of course the machines desperate effort to tell you it's problems and the code may be in the owners manual or a call to the manufacturer.
I'm a big one for checking grunge accumulation and would ensure the discharge hose is clear. This gets back to hearing water leaving the machine. You may need to pull the unit to check the hose, although a common blockage is right at the connection to your disposal.
Also, check for debris under the filter screen in the bottom of the tub, another place detritus accumulates.
All the best.
Nov 22, 2014 | Dishwashers
FDB1050REC2 no water
If water runs back into the drain then your drain hose is not properly afixed to the top of the unit under the cabinet. It must be at the top of the unit so no more than a half of an inch of water falls back into the tub when finished.
Dec 26, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
My model DU810swkqo dishwasher will not drain completely [leaves about a couple of qts of water in the bottom after cycle.It has started dripping water out the bottom of the door.Can or does it need drain...
Hello
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Aug 06, 2011 | Dishwashers
GE model #GSD5130D00WW Dishwasher leaves standing
There is a valve in the rear of the machine under the screen. If it is worn will not drain well . unscrew the valve and check whether the rubber cone is still all there. run in pump cycle with the valve out to clean the unit out.
Dec 03, 2010 | Maytag Dishwasher
My KitchenAid model KUDSO11JBSO dishwasher stopped running before the last cycle (drain) finished. All the lights and any response from the touch pad have gone out. There is still power to the junction...
Try shutting off the power at the breaker, leave it off for 45min. This will reset the unit. If you had a power spike this will fit the issue.
Nov 09, 2010 | Dishwashers
Water standing in tub
If there is a lot of water sitting inside the applicance, it's possible that the high water float switch has been activated and is preventing the dishwasher from running. Open the door, remove the bottom rack, dip as much water out of the bottom as possible with a shallow ladle or even tupperware container. When that is accomplished, shut the door and try to run a drain cycle. If the unit won't start, you may have to remove more water. You don't have to have the rack in place to run the drain cycle.
Jul 09, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Fisher & Paykel DS605 starts cycle, stops, beeps, shows U3 error.
U3 means the tub filled to quickly or the water failed to drain. Do you have very high water pressure? are you using the wrong detergent? eg you can't use tablets (powerballs) etc in the unit. Try putting half a cup of white vinegar in the tub to kill any foam. Check there isn't anything stuck under the motor rotor inside the tub and the there's no signs of damage. Put the drain hose in a bucket and see if the water drains ok when the unit starts? If everything seems ok I'd suspect the main motor controller module but it may be worth getting an appliance tech to inspect unit first as it's hard without seeing this unit. feel free to ask any questions. Cheers
Apr 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water left in bottom of Bosch dishwasher
One possible solution to your problem could be as follows... Could have been little regular soap or something put in that made it suds up causing it not to drain. Pouring vegetable oil into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 10, 2009 | Bosch SHV4803 Dishwasher
Kenmore Ultra Wash Model 665 Dishwasher
Dishwashers which are properly installed and regularly used won't normally have a problem with bad odors. Check the following: ?Was the drain hose brought in at the top of the cabinet, or down near the floor? it must be 34" from the floor. ?Do you run the unit at least once every 2 days? -Run a cycle with a quart of vinegar to clean the tub and pump. ?Does the disposal tend to back up slightly when the dishwasher drains? Drain may be clogged. -Don't use gel detergent! ?Check your water softener(If so equipped) These can cause foul odors in the water supply if not properly balanced or maintained Good luck!
Sep 02, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
121 people viewed this question
Top Dishwashers Experts
