Burning smell and battery not charging
I have a new battery and a new ac adapter but when the computer is plugged in there is a burning smell.
  • 322 Answers
The conector on the motherboard have the contacts unsoldered, if you use the computer in this condition you may have to replace the mb.
Posted on Jul 16, 2009
    Scholar:
  • 104 Answers
Most of the companies now a days replaces the system for you if the problem comes under fire hazard. Even if you smell that something is burning in your system you can get your system replaced from the company without any cost
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
Averatec 3700 notebook is charged but will not power on, nothing happens when power button is pushed even when power cord is plugged in
Try to remove the battery and turn the computer on with only the AC adapter connected. If it works then the battery is failing. If it does not there is something wrong with the motherboard or the AC adapter. hopefully it is just the AC adapter. Try to borrow an AC adapter from a friend or anybody else. Make sure that the current and power rating is exactly the same. Or else you might end up with a burned laptop. It the known working AC adapter works, then it is your charger. Buy a new one.
Jul 04, 2011 | Battery Technology Battery Averatec 3700...
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Gateway lt21 netbook not charging
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 13, 2010 | Gateway Computers & Internet
New AC Adapter Will Not Charge Battery/Operate Computer
Most probably static electricity killed some circuitry inside your laptop.
Nov 12, 2009 | Acer Aspire 3610 Notebook
My AC power supply runs the laptop but will not charge the battery (plugged in, not charging). Laptop also runs ok on battery only. Some burning smell noted from AC input before problem
If you have a burning smell I would not plug it in again it may could cause a fire. I would take it in for service and have it checked out.
Jun 11, 2009 | ASUS F3Jc-AP141C Notebook
Bought new AC adapter but connected it with wrong polarity
Hate to ask the obvious but have you replaced the batteries?
Jan 03, 2009 | Archos Jukebox Studio MP3 Player
Burning smell on my laptop
Unless you have the ability to to replace the plug connector part yourself, you will have to take it in to a shop who can do that kind of fine soldering for you. If nothing else is damaged, it should be ok with replacing just that burnt out part.
Jul 12, 2008 | ASUS Computers & Internet
Notebook smells like burning plastic.
cud be your onboard voltage regulator for the battery charging. if you remove the battery and use the external power source does it smell also?
if the battery charges normal out of the unit, and the laptop works well with the AC power unit without the battery, then it's your voltage regulator for the batt charging
Mar 17, 2008 | Computers & Internet
If the new Targus charger is really rated correctly for your laptop, your battery isn?t charging and you smell the burning plastic coming from the laptop when you plug it in that is a fairly dangerous situation and you shouldn?t plug it back in anymore. The power from the charger runs through a PCB board which distributes power to other components in your laptop. I suspect one of the components (probably a capacitor) had a catastrophic failure and is the cause of the smell and the lack of battery charging. Once again assuming that the Targus is the correct one for your laptop current you probably have a laptop damaged beyond home or economical repair.
Dec 02, 2006 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
304 people viewed this question
David Payne
David Payne
