Question about Amana NTW5205TQ Top Load Washer
I need to put a new belt on my washing machine, model # S68PXMCM-1069 .. where do i start taking my machine apart? I have the front panel off
    Problem Solver:
  • 9 Answers
Front pannel , belt should be under basket
Posted on Jul 16, 2009
Reattached tub, but spin cycle doesn't work
the belt might have come off of the tub take it back apart and look underneath and see if the drive belt is loose or on the floor when the tub came loose it probably slipped the belt off before stopping.
Dec 12, 2007 | GE Profile Prodigy WPSE4200A
How to change the belt on a hotpoint wma54 washing machine
there is a rear access panel in the center of the back,remove this cover and put the new belt on the motor pulley,then over the larger drum pulley,it takes some strength unless you release the motor tensioner and retighten after the belt is on
Mar 23, 2010 | Hotpoint WMA54 Front Load Washer
I have an amana washer...Model # 8318015...The belt is broken..I have a new belt that I need to put back on, and I need directions on how to do this
take the bottom panel out(2 screws) then the upper panel out(its clips)
now the pump need to take off the shaft 3 screws then you can put the new belt in it with tention from the pully roller... try to see if there are video for that in youtube...good luck not so EZ to do :(
Jan 02, 2010 | Amana ALW480DA Top Load Washer
Belt replacement on GE top loader WJSE4150B2WW
Your post shows a model WJSR2070B and a model WJSE4150B2WW but in this case the procedure is the same. Use a putty knife to push in the clips at the top seam of the front panel, where the front meets the top, about two inches in from each side. Tilt front panel forward and lift off bottom pegs. Loosen the four nuts holding the motor with a 3/8 inch wrench so you can push the motor back a bit. Take old belt off. Install new belt (WH1X2026), putting belt around motor pulley, part way on big pulley, then turning big pulley by hand to ride it onto the big pulley. Use one hand to pull motor toward you to put a little tension on the belt as you tighten the four nuts under the motor.
Nov 30, 2008 | GE WJSR2070B Top Load Washer
Take apart washer
Please provide the brand name to assist me in assisting you.. Thanks
Aug 30, 2008 | Washing Machines
Take apart washer
just remove back ...don't remember seeing broken belt on duet except the sport version..as far as control panel remove top a couple of screws top front and snaps in at bottom but IF AIN'T BROKE DON'T FIX IT
Aug 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
DRUM WON't TURN on my Roper Dryer
you can put the back back on, remove the 2 screws under the lint filter( if ones mounted to top of machine ), then the top tips back revealing 2 5/16 screws holding the front panel on. lift off hte panel and string new belt arond drum and hook ove rht e motro pulley , first passing the belt through the idler tension pulley. belt number is a 341241
Mar 12, 2008 | Roper RES7646KQ Electric Dryer
How do I fit a new belt on my Indesit Wil 113 washing machine?
I think its a 'front Loader'? Take the back panel off, to expose the main drive belt & pulley. When fitting the new belt it needs stretching by first putting it around the motor drive shaft & easing on to the main pulley whilst gradually rotatng the pulley. You need to finish up with the belt in the centre of both of the pulleys if possible
Oct 31, 2007 | Indesit W 123 Front Load Washer
Open Questions:
Amana NTW5205TQ Top Load Washer Logo
263 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
