SOURCE: Micro-sd card capacity
absolutely. the first time you pop it in, your phone will ask you if you want to format it. select 'yes' and then you will find several new folders for pix, flix, music, etc.
SOURCE: micro SD card wont work
type 277634# * # (no spaces)
click port setting
click mass storage
click mass storage remove
go back to main screen and check again for memory
if this doesnt work,take out memory card and try without the memory card.
SOURCE: What size micro sd for my Samsung Sync cell phone
anything over 2gb is a micro sdhc the hc means high capacity so for most phones 2gb is the most you can go thats why the 1gb works and not the 4.
SOURCE: My LG Chocolate VX8550 wont recognize micro sd card
Here are the steps I took:
for mp3 as ringtones:
SOURCE: 8gb micro sd card does not work. lg vu cu920. is there a fix
I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
