Question about Milwaukee Tool Case Heat Gun
NO DRIVE WHEN GEAR SELECTED THE HANDBRAKE LIGHT IS STAYING ON . ON THE DASH
    Scholar:
  • 172 Answers
Check to make sure the handbrake is completley off. Since I don't know what kind of machine you have, I'll have to give you a generic fix. The handbrake has a switch which turns on a light to let you know it is engaged. In addition it most likely sends a signal to a nuetralizer valve in the transmission which dumps pressure back to sump preventing gear engagement, so you can't drive with the handbrake engaged. If the switch is out of adjustment, the handbrake may be released and the switch can still be on. Check at the bottom of the handbrake handle for the switch. I have found that if you are a little forcefull in releasing the handle, a lot of times the switch will make the right contact. I'm 99% sure this is the problem. Marvin T.
Posted on Jan 27, 2010
The dashboard light for brakes and handbrake stays on even when driving
I had a similar problem with my handbrake light the problem was a faulty handbrake sensor. The brake light stays on because of a fault in the system the handbrake. I just disconnected the handbrake sensor
Apr 23, 2016 | Cars & Trucks
Why Is a power light on in the dash board
Have you looked down by the gear select to see of there is a "power" button?
Sep 14, 2014 | 2000 Kia Sportage
My handbrake light stays on on dash
use a scanner to tell you exactly the fault .
Sep 13, 2012 | 2007 Daihatsu Terios 1.5i
Stop and handbrake dash lights staying on whiledriving.
Hi there
Check your brake fluid level, if that is right then check your handbrake switch. Sometimes the locknut gets loose.
Apr 25, 2011 | Renault Sport Cars & Trucks
I'm driving an automatic gear car. At traffic light, do I put gear to neutral and pull handbrake, or do I continue to step on the brake. Any difference on either action.
just keep your foot on the brake. It cannot do any damage, the auto box is designed for this
If you put in neutral you risk making a mistake and selecting reverse. or may not select gear inadvertantly on a hill and roll backwards.
May 27, 2010 | Toyota Yaris Cars & Trucks
LIGHT WARNINS ON DASH
this is the low tire pressure warning
Mar 12, 2010 | 1995 Mitsubishi Diamante
Isuzu Trooper 1997. Automatic Transmission holds gears too long.
Their is a power and normal drive in trooper's power for pulling a trailer and normal for normal driving. The power drive only changes gear at higher R.P.M. Their is a switch on the plastic cover under the handbrake with p & n their is a light in the dash as well. If you are not aware of this switch then just needs switching over if you are aware of it then its probably the fuse to activate it or a wiring problem with it, Cheers
Sep 24, 2009 | 1997 Isuzu Trooper
1994 daihatsu Applause handbrake light wont go off!
check your brake fluid level i had same problem on a different car with handbrake light staying on and when i checked brake fluid it was on minimum light went back to normal after topping up fluid in the reservoir check the fluid "DOT" rating before buying this should be on the cap (ie DOT 4 fluid only)
May 28, 2009 | 1992 Daihatsu Charade
Rear brake lights always on
sounds like brake pad sensor damaged or did you forget to put in new pads or removed? if its got one.
low fluid in brake reservoir can cause light to stay on also
or hand brake light switch shorted to earth have seen coins jammed in there b4
My Mercedes ML 270 cdi ABS etc lights and gearbox.
  • you need a Brake safety switch replaced.This is located behind you brake pedal.it's a common problem. The warning lights will reset after a few engine starts.
May 18, 2009 | 2002 Mercedes-Benz M-Class
Milwaukee Tool Case Heat Gun Logo
651 people viewed this question
Top Milwaukee Tool Air Tools & Compressors Experts
John Trevino
Geert Deschamps
Are you a Milwaukee Tool Air Tool and Compressor Expert? Answer questions, earn points and help others
