Question about HP Officejet 5610 All-In-One InkJet Printer
I have the Officejet 5600 all-in-one series. I
I have the Officejet 5600 all-in-one series. I shut off the power yesterday, 7-14-09 to try and "reset" a scan issue. NOw I can't get the power back on. Thereis power going to the all-in-one, but the ON button doesn't turn the printer on. It doesn't light up, OK, SETUP etc., nothing works. Tried the #3, #6, and #9. There is a black bar/boxes across the face of the all-in-one. Uninstalled and reinstalled software....okay, what now?
  • klpeifer Jul 16, 2009
    FYI I have XP. I've faxed, copied, scanned etc., in the past. It's like the keys are not being recognized.
2 Suggested Answers
tumi001
  • 102 Answers
SOURCE: OfficeJet 5610 Won't turn ON
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab6
Posted on Jul 17, 2009
Officejet 5600 series printer driver
you can download the drivers/support from HERE
Oct 30, 2013 | Computers & Internet
My HP5600 printer had a paper jam which I cleared. The printer still indicates a jam and I cannot get it to print.
try shutting it off and remove all cables connected with the printer. wait for a few minutes and connect all cables back and then switch on the printer. meanwhile, also shutdown your PC and turn it on again too. now try printing, it should work fine.
hope it helps.
Feb 18, 2011 | HP Officejet 5600 series
HP5610 All-In-One will not turn on
Sounds funny....try to open and remove the cartridges, and then power on.... the black bars usually indicate some kind of electrical problem, and it is usually the carts...open the printer, remove the carts, ( you may have to gently slide the carousel over for access ) and close power down, and remove the power. Then reverse...let me know if this helps...
Jul 21, 2009 | HP Officejet 5610 All-In-One InkJet...
hi,
ab6
Jul 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Have Lexmark 5600 series all-in-one. Can't get it to enlarg pictures by copy or scan. Help . Tried everything in the productive suite.
In regards to Lexmark 5600 series all-in-one printer not being able to enlarge photos. I had been trying to use computer programs from the installation disk. Forget that and simply use controls on printer itself. Just use the copy button and set paper size. That easy. Thanks for your help.
The best,
James Sewell
Jun 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Can not scan legal documents
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
alkkk-4
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp 5600 printer will not effectively cancel print
Please try to following these steps :-
1- Try to run print spool services from the services.msc
just type :- services.msc in the run command.
then restart the print spooler service.
2- Try to delete unprinted page from the print command.
3- Please download HP printing diagnostic utility for check printer problem :-
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-2&cc=uk&lc=en&dlc=en&product=3221646
4- Try to uninstall and reinstall the printer.
please install the driver from the following link ;-
http://download.cnet.com/HP-Officejet-5600-series/3000-2116_4-80627.html
May 05, 2009 | Computers & Internet
New Hp Officejet 5610 All-in-one - Printing?
You may have a couple of problems. First, you say you have more than one icon in your Printers dialog box for 5600 series printers. My guess is that you installed two different drivers, one for the 5600 and one for the 5610.
Try deleting the 5600 printer icon and making the 5610 the default printer. Run the test print again to verify it works, then open a Word document and see if you can print that.
This brings me to the second issue; what exactly are you trying to print? The issue in this case, may not be the printer but an issue with the document. Some documents have a security feature that prevents printing. Try different documents (Word, Excel, etc...) and see if the problem is across the board. Post the results here.
Thanks.
Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
Printing
hi,
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
adonscott
Apr 04, 2008 | HP Officejet 5610 All-In-One InkJet...
Installing HP Officejet 5600 all-in-one in Windows Vista
Go to hp.com. Click on 'software and driver downloads' (on the left of the screen). Next to 'for product:' type in Officejet 5600' and click the >> symbol. Then choose from the list that comes up. When in doubt, choose the first on the list, HP 5605 All-In-One. On the next screen select 'software and driver downloads' again. There you'll see where you can select Windows Vista. CLick on that and sleect, under "Driver", HP Full Feature Software and Drivers.
On the next screen, scroll down and select 'Install Now'.
Best wishes, Al
Mar 08, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
