Question about Bose 3 2 1 GSX System
I put in a dvd and i get format not supported?bose 321 gsx system
I put in a dvd and i get format not supported? bose 321 system
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
-If this happens on all DVDs, then this may need to be repaired (Bose will repair this for free if this is the case- they can test it too) -If this happens on some or most DVDs, you can try a firmware update. Call Bose at 800-367-4008 and tell them about this. Request the most recent software/firmware update disc.
If you haven't already, just try resetting this first. (unplug the power cord from the acoustimass module for about 30+ seconds and try again)
If this happens primarily on rentals or home-made dvds, an update will most likely fix the problem.
Posted on Jul 17, 2009
  • Jo booth
    Jo booth Feb 04, 2015
    Thanks Chris I unplugged and now I've got my music back cheers Jo
  • Jo booth
    Jo booth Feb 05, 2015
    But after one hour it's done it again so I unplugged again no joy this time
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
BOSE 321
HI,
Go for a rest first by unplging it for 30min and then plug it back see if this helps or call tech support to oder an update disk.
Goodluck,
Please don't forget to rate the solution
May 01, 2008 | Bose (321GS) System
Unsupported format
I have the same problem. When I put in a dvd it tries to read it and then comes back unupported format. What does this mean and why won't it read the dvd?
May 05, 2010 | Bose 3 2 1 GSX System
I have a friend with a 321 system. He says it
Unfortunatley no, its not software that reads dual layer discs, its hardware. I sold Bose for 2 years and do not know of any Bose items that will read dual-alyer discs. Dr. Bose has a hard time keeping up with technology sometimes. Other than that, the 321 is a great system!
Oct 02, 2009 | Bose 3 2 1 GSX System
Our Bose 321 Entertainment System is only playing DVDs in black and white - no color at all.
Be sure that in the setup menu, you are selected for the correct output format (either component which is BLUE/RED/GREEN + audio or composit which is just YELLOW + audio. If that is correct, I would suggest a call to the BOSE technical support center.
Sep 08, 2009 | Bose 3 2 1 GSX System
My BOSE 321 GSX, was working just fine. I was listening to a CD and started storing it, then someone else tried to stop it, and pushed the on/off, source and eject buttons at the same time. Since then it...
you can open it up and see if you have broken the ac/dc converter. disc tray could have jammed it up. if you dont know much about them then try calling customer support. ^^
Jun 14, 2009 | Bose 3 2 1 GSX System
Bose 321 System
its the format of the DVD as its written.
Nothing you can do but to have the DVD re-authored.
We had this problem with out wedding video. It runs fine on my computer but not in the Bose. We asked the videographer to reauthor the DVD explaining the problem and it works now.
Sep 13, 2008 | Bose 3 2 1 GSX System
Format unsupported
Format unsupported simply means the unit can not read the disc. The problem is either the disc or the player.
Contact Bose technical support if you are sure the discs are good. 800-367-4008
Jul 31, 2008 | Bose 3 2 1 GSX System
DVDs with pictures refuse to play. Get 'format unsupported'
the 321 does not support data cds or dvds read the manual. standard DVD or VCD format only.
Nov 23, 2007 | Bose 3 2 1 GSX System
Bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Nov 13, 2007 | Bose 3 2 1 GSX System
Bose 3 2 1 GSX System Logo
1,202 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
