Question about NetGear WG602 54Mbps Wireless G Access Point (S2546037)
Wireless won't connect
Inspiron 4150 with TrueMobile 1150 wireless.
WXP
Netgear WGR614 router
My IBM laptop connects to the router just fine
Inspiron finds the router/SSID
I have put in the WEP key.
But it won't connect.
Any ideas?
I
  • 2 more comments
  • artkr Jul 16, 2009
    Dell is running xp sp3 (It didn't work on sp2 either).
    I disabled the microsoft forewall and it didn't work.
    What do you mean by disabling wireless security? Do you mean getting into the router and disabling it there?
    TIA
  • artkr Jul 17, 2009
    disabled WEP in both the router and the inspiron.
    No change. Still won't connect.
  •  C. Dante
    C. Dante May 11, 2010
    Yes - that's what I mean. the reason is to see if there is any problem with the wireless encryption. If the Inspiron connects with disabled wireless security, we found the culprit and can take it from there.
  •  C. Dante
    I have two questions:
    Is your Dell Inspiron running WinXP as well?
    Does this laptop connect when you disable wireless security?Come back here and let me know - I'm happy to help.
  • 1,272 Answers
Perform the steps below to configure wireless connection settings on the concerned computer:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 17, 2009
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
Have a wireless network through netgear WGR614 v6 working fine with 2 old ibm/toshiba laptops with vista and an acer on ethernet recently bought a new hp laptop with windows 7. This laptop gets very...
check if the laptop has wireless utility other than the built in windows wireless. (example intel proset wireless). if yes, uninstall the wireless utility and Update the wireless driver of your laptop by downloading the latest driver from ho web site.
Jun 10, 2010 | NetGear WGR614 Router
Netgear wireless wgr614 is configured and the ports wired connected and is working ok while wireless portion the laptop running vista says connection is limited and unable to browse
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Apr 07, 2010 | NetGear WGR614 Wireless Router
Lost of connectivity of my wireless connection of my laptop
Please check your laptop is getting wireless signal or not from your router.
If not then check your router is working fine or not with other device also.
Mar 31, 2010 | NetGear WGR614 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Connection
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Problems connecting my laptop to wireless router
Make sure that you do the setup via cable, not through wireless!
If you change form WPA to WEP, the length of the key changes and you will have to provide this new key if you want to connect wireless to your router.
You can leave your laptop connected via cable and check if your wireless card can connect.
No, you don't have to reinstall everything again. Just plug in the cable, connect to your router (192.168.x.x) and check your wireless setup.
Dec 28, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Problem
dear leetheone,
your network wireless is not properly set up. you have to properly set this, try using the windows wireless wizard and follow the prompts.
sid
Dec 02, 2007 | NetGear WGR614 Wireless Router
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
NetGear WG602 54Mbps Wireless G Access Point (S2546037) Logo
201 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
