Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Primary mower belt on my Craftsman 48" lawn tractor has worn out prematurely. I installed a new belt this spring, & after less than 25 hours of service, it is 75% shredded from the inside. When I installed it, it didn't appear to be rubbing on anything, as I ran it in the garage with the clutch engaged to test.....please advise what could be causing the premature wear....
  • 10,865 Answers
Hi. The belt must be trying to move a pulley that is either frozen, partially frozen or excessively loose. remove the belt and check the action of each pulley. If you have a frozen one, use some WD-40 to unfreeze it and if you have an excessively loose one replace the entire pulley assembly as it is worn out.
Posted on Jul 15, 2009
Yth2248 loses speed on slightest grade. new drive belt not helpful
Roy if it is the correct belt and fairly new, check your manual for belt adjustment, if it shows that there is no adjustment the pulleys may be worn out, on a lot of mowers the pulleys are ware items and changed more often to correct slipping issues. The other thing to check is the belt tensioner if equipped, it could be seized, weak or missing spring or it may even be adjustable by cable end being threaded or slotted bolt holes on tensioner arm.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Drive Pulley Replacement On Craftsman Lawn Tractor
Mower Engine Pulley Replacement Craftsman Riding Lawn Mower Repair Part...
Cub Cadet LT1045 Transmission Drive Belt Replacement
husqvarna LGT24k54 drive belt install
Apr 22, 2016 | Garden
Primary belt rubs on bracket n keeps shredding/// new replace ment deck...just purchesed
Look under the the left foot rest,there is a belt installation diagram. It will show how to install the belt correctly. It is real simple to replace belt,but the belt must be installed on the pulleys,correctly or it will fail,every time. Sincerely,Brad Locke
Jul 27, 2015 | Craftsman Garden
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Craftsman 42 in Deck Lawn Tractor jerks/bucks when in forward during turns. Is there an adjustment or do I need a new belt?
Sounds like to me you need a new belt! The belt is automatically tensioned by a spring on most mowers by MTD, the major mfr for most mowers including craftsman.
Apr 20, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to install clutch in craftsman lt 1000
there is no clutch,, you have an arm with a pulley that is spring loaded .. when u release the " clutch" this arm pulls a pulley against the belt taking up the slack ,, make sure the belt is not worn ,, or the spring is broken or loose
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Im having a problem with the mower primary v
Most times, belt wear is the result of mis-aligned pulleys and guide pulleys or damage to them from foreign objects. Some are spring loaded, and if the spring is not positioned properly, the tension on the belt is affected and the belt will prematurly wear. Check to be sure that each pulley is smooth, and rolls freely, some will have grease zerks that should be periodically lubricated, some will be factory sealed for lubrication. Look at the belt to see if fraying is present (bad pulley, or alignment) or just a break that might indicate a seizing up on one of the pulleys. Any objects in the belt path?
Apr 15, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Cant get a deck cutting belt for model YTH 2448T960430008 48 INCH CUT TRACTOR MOWER
which belt do you need the primary or secondary i have part # for ya i can also order them 180808 & primary part # is 174368 let me know if i can further help thanks wade
Jul 07, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How to replace the drive belat on craftsman 917273280, 21hp, 48 in cut?
you remove shield from engine remove belt, remove deck from mower and remove pulley guards and install belt replace guards , reinstall deck, put belt on engine pulley replace guard
Jul 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
May 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
477 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
